Paint Help: Engine Cover Debacle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cdn_bacon, Feb 7, 2010.
  1. Feb 7, 2010 at 7:41 PM
    cdn_bacon
    cdn_bacon [OP] Well-Known Member
    Christopher
    Houston
    07 Tacoma Dbl Cab short box 4x4 TRD
    Slim's HID 6000k headlights and fog lights; Redline hood and tailgate struts, TRD CAI
    So I thought for something to do today I'd paint my engine cover. I got it off, took my time masking it and had it perfect...started spraying and finally got a nice even thick coat on it and WHOSH.....damn gust of wind blew up and blew some dust and small debris into my garage and all over my bloody cover and stuck to the paint. I thought I could wipe it down while it was wet and get it off enough to start over but it turned into a mess.
    So how do I clean this up to start over? Paint thinner or sand it? What grit sand paper? help?:confused:
  2. Feb 7, 2010 at 7:42 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    let it dry and sand it again
  3. Feb 7, 2010 at 7:42 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    320 grit
  4. Feb 7, 2010 at 7:46 PM
    Munkey
    Munkey Well-Known Member
    Paducah, KY
    2008 Radiant Red 4X4 Double Cab Sport
    OEM Tube Steps, Bed Extender, Pioneer Avic D3 with Bluetooth and XM Radio modules
    Wet sand it with 280 until most of the paint is gone. Then wet sand with 400 to get it really smooth, then paint again. Whatever you do, don't use paint thinner or remover on it. It's plastic, thinner will eat it up.
  5. Feb 7, 2010 at 7:55 PM
    cdn_bacon
    Christopher
    Houston
    I was going to get thinner but stopped and started thinking about that. What about a light wipe with thinner (LIGHT). How do you wet sand? Is it a diff paper than dry sanding?
  6. Feb 7, 2010 at 7:56 PM
    Tsenekos
    Greg
    Edmonton, CANADA
    ya the paper is wet in wet sanding but the technique is the same
  7. Feb 8, 2010 at 6:23 AM
    Munkey
    Paducah, KY
    Just keep a bucket of water near by and dip you sandpaper in it every few minutes. Wet sabding keeps the paper from loading up and will give you a better finish.
    I light wipe with thinner migh work but the potential to do damage to the cover is there so I wouldn't risk it. I wouldn't do it unless you were prepared to buy a new cover in case it hoses the cover.
  8. Feb 8, 2010 at 9:46 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    sand it down and use plasti dip on it, it's kind of like a thin line-x. I've used it for dozens of projects, it works awesome and it incredible durable. Obviously with the name plasti-dip its for plastics but it also works great on everything else i've tried including wood and aluminum
  9. Feb 8, 2010 at 9:49 AM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    Delray Beach, FL
    2007 Infiniti G35S
    I add a few drops of dish soap in the water bucket when I wet sand.
  10. Feb 8, 2010 at 9:51 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2010 4Runner Trail Premium
    Bring it with you on sat i will fix it for you ....
  11. Feb 8, 2010 at 7:35 PM
    cdn_bacon
    Christopher
    Houston
    It has been fixed. Spent the last 2 hours sanding and sanding and sanding and finally got it all cleaned up, remasked and painted (with the garage door down!)...mind you I think I'm stoned and painted my lungs :p
    So here's another question. Because I sanded it it wasn't 100% smooth so my painting job has resulted in a textured look. Can I sand that smooth before clear coating it ?
  12. Feb 9, 2010 at 7:01 AM
    Death_Stalker
    Talha
    Cypress, TX
    NOooooooooooooooooooooo you can't .... even the finest sand paper will take the pain off .. dude i think painting is not your thing ... lol dont mess with it ....
  13. Feb 9, 2010 at 7:02 AM
    Death_Stalker
    Talha
    Cypress, TX
    oh btw no point painting your lug nuts .. the paint will come off next time you change your tire or take the tire off for any reason ...
  14. Feb 9, 2010 at 7:07 AM
    cdn_bacon
    Christopher
    Houston
    Painting is def not my thing!!
  15. Feb 9, 2010 at 7:52 AM
    Death_Stalker
    Talha
    Cypress, TX
    i can see
  16. Feb 9, 2010 at 7:59 AM
    GotLift37
    GotLift37 Bangers Runner
    down south
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion
    lol to start off even the paint can says use multiple light thin coats. you messed up from the start. your paint is going to melt off now... lol jp man. hope it turned out good.
  17. Feb 9, 2010 at 8:11 AM
    Death_Stalker
    Talha
    Cypress, TX
    yeah i;;; look at it sat and see what we need to do to fix it im sure i can fix it for him .... im a pro when it comes to painting .... ;-)
  18. Feb 9, 2010 at 9:25 AM
    cdn_bacon
    Christopher
    Houston
