paint marks under door seals
Discussion in '2nd Gen. Tacomas (2005-2015)' started by martthewhite, Sep 29, 2014.
  1. Sep 29, 2014 at 9:59 AM
    martthewhite
    martthewhite [OP] Active Member
    Montréal, Canada
    2010 TRD OR ACLB
    Sliders, SCS6 Wheels, OME full set-up, bump stops, Banks Exhaust, TRD Intake, TRD short shifter, Floortech mats and Best Top Canopy.
    My passenger door seal is leaving a mark (grouving) to the painted door frame :mad:. Specially near the top of the truck. Is anyone had the same issue ? and have you readjusted the door for a tighter contact ?
    I normally keep the doors seals clean, it's the first time a I got mark on a 5 years old truck. I will lube the seal and wax the car body. Any advise or recommendation ? thanks
  2. Sep 29, 2014 at 10:15 AM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    Slight frame tweak? Causing the door to rub wrong, dcsb/dclb? do a lot of wheeling?
  3. Sep 29, 2014 at 10:20 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    If it's leaving a mark now pretty sure making them tighter is not what you want to do.
    and yes I do have marks on my frame from my doors. These truck body's flex like crazy and it's going to happen so I'd suggest adjusting it with the help of a friend to make it easier on you.
  4. Sep 29, 2014 at 10:24 AM
    martthewhite
    Montréal, Canada
    2010 TRD OR ACLB
    2010 ACLB TRD OR with only 50000 Km (31000 miles)
    Light wheeling before I had my childs but mostly street use since 2 years. Nothing hardcore, I still have the oem suspension.
  5. Sep 29, 2014 at 2:07 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    They sell a clear plastic adhesive backed sheet that can be cut and applier over the paint area to prevent wear through.
