Paint on Hood Very Bad, Options?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SilverhawkDad, May 19, 2019.
  1. May 19, 2019 at 8:49 PM
    SilverhawkDad
    SilverhawkDad [OP] Active Member
    I just become the newest owner of a 2000 Tacoma Pre-Runner V6 Xtracab. It's in great shape mechanically and the interior is great. The body is in good shape but the paint on the hood is very cloudy and in bad shape. I spent the weekend trying to correct and polish it but no matter how shiny I got it, within an hour or so it went back to being cloudy. I think this means it's kaput.
    This is how it looked originally. The rest of the body is free of cloudiness and shined up decently given the age of the vehicle.
    I'm trying to think of my options. Getting the hood repainted? It would never match the rest of the vehicle, I don't think, would it?
    Maybe covering the hood in some carbon fiber wrap? Ugh, that would probably look silly.
    Any other thoughts or comments?
    Taco critter likes this.
  2. May 19, 2019 at 9:07 PM
    DPTacomaGuy
    DPTacomaGuy Well-Known Member
    David
    2001 Tacoma 4x4
    Depends on what you want. Body shops can do a pretty good job of matching colors. I’d be looking into top surfaces as they will be next to fade on a 18 year old factory paint.
  3. May 19, 2019 at 9:12 PM
    rustytoys
    rustytoys Active Member
    USA
    1999 Toyota Prerunner
    Sure a good shop could match it just fine, but that is dependent on your budget. If you want it done cheap just take the whole hood off and maybe shop smaller independent guys, by just giving them the hood itself then at least you dont have to worry about them causing overspray damage all over the place.
    Great looking Tacoma, I think it has 4runner wheels maybe? not sure if you knew that.
    GQ7227 likes this.
  4. May 20, 2019 at 4:33 AM
    04TRDV6
    04TRDV6 Well-Known Member
    Lynn
    Houston, TX
    2004 TRD V6 XtraCab
    My hood and roof were bad. Plus some rock chips in the hood that were starting to rust. Took it to Maaco and got the base + clear option for $1850 I believe. Didn't have them fix any dents or anything extra. Was more concerned about just stopping the rust.
    Edit : that was for the whole truck. Not just the hood and roof. I figured there was no way it would match without doing the whole thing. And that would bug me.
  5. May 20, 2019 at 5:51 AM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Hard to tell from the pic, but what is the actual condition of the paint on the hood, besides it "looking bad"
    Any peeling clear coat, chipping, all the way down to metal?
  6. May 20, 2019 at 5:59 AM
    RedManRocket
    Red
    2002 Double Cab LT
    Lol maybe not, I've got a few more questions to see what would be the best route, I worked in a body shop for a few months so I'm pretty much a pro :muscleflexing:
    :rofl:
  7. May 20, 2019 at 6:34 AM
    Indy
    Indy Master of all I survey.
    Plastidip or get a respray.
  8. May 20, 2019 at 6:51 AM
    hubcapsc
    hubcapsc Un-Known Stranger
    Upstate South Carolina
    2002 6cyl 4x4 manual
    Someone backed into my car this year. Never having had to go to a body
    shop or deal with insurance quoters, I was confused about everyone talking
    about messing with the adjacent panel that was undamaged... the good body
    shop man I took it too explained about "blending" to make is so that the
    newly painted panel wouldn't stand out. I guess he blended the snot out
    of it, because I can't tell the difference...
    -Mike "they can make it match pretty well..."
  9. May 20, 2019 at 6:53 AM
    SilverhawkDad
    Okay, so I used a polisher from Harbor Freight using a orange pad, I think it's for correction. I used Griot's Garage Complete Compound on the entire hood. All of it was cloudy, now after working on it over the weekend some spots remain cloudy. Many of them seemed to clear up but after an hour in the sun driving around went back to cloudy. Some spots such as the front edge of the dash did clean up pretty well. Here's some pictures.
  10. May 20, 2019 at 7:00 AM
    rustytoys
    USA
    Maaco is a franchise, so the service and management can likely vary a lot from one location to the next, but you got to be so careful of overspray with them, they can overspray your entire engine if there are any vents going to it, they can not tape your rubber window seals right and then you have all your nice seals half painted, if you have brand new tires they can overspray them too, its honestly scary sending a nice car to Maaco - but again its a franchise so if you have a good trusted one that painted your truck good then thats great, Maaco usually lays on really nice paint jobs, its just a prep taping issue where corners are sometimes cut - but this will probably depend a lot on each particular franchise location.
  11. May 20, 2019 at 7:29 AM
    RedManRocket
    Red
    2002 Double Cab LT
    Did the pad turn red when you were polishing or did it stay orange
  12. May 20, 2019 at 7:31 AM
    RedManRocket
    Red
    2002 Double Cab LT
    Nevermind OP just read the bit under your picture, paint is coming off
  13. May 20, 2019 at 7:34 AM
    RedManRocket
    Red
    2002 Double Cab LT
    So here's what I suggest, not knowing the depth of the paint since some of the clear is gone, might not be worth it to ask a shop to do it yet. So, take some 1000 grit wetsand sand paper and do a section of the hood, or just a spot to see how it'll look. If it comes out looking good and youre still not into primer you can take it to a shop and have them wetsand and reclear the hood for you, will be much cheaper, and look just as good.
  14. May 20, 2019 at 7:42 AM
    Rujack
    Rujack Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
    Careful going too crazy with the compound. You might go all the way through the paint.
    Cloudiness can sometimes mean there’s moisture trapped in the paint or clear coat. Not sure what they were using in 2000 or what type of color you have there - base and clear, or single stage.
    Have you tried a heat gun or infra ref light?
  15. May 20, 2019 at 7:45 AM
    Rujack
    Edit: that pic of the buffing pad looks like you’ve got either single stage, or the clear is gone, possible that you’ve cut through the clear (if it was there) down to the base, in which case you’ll have to repaint / clear coat it now.
    I agree w redmanrocket.
  16. May 20, 2019 at 7:47 AM
    RedManRocket
    Red
    2002 Double Cab LT
    Only white and black I believe was single stage so he's already through
  17. May 20, 2019 at 7:48 AM
    Rujack
    Bummer. Ah well.
    RedManRocket[QUOTED] likes this.
  18. May 20, 2019 at 7:48 AM
    RedManRocket
    Red
    2002 Double Cab LT
    That's why I suggested a reclear, we did it plenty of times at the shop I worked at
  19. May 20, 2019 at 7:53 AM
    Rujack
    Possible that the hood was previously repainted which might explain why the other panels still look good. Is it the original hood? Do you see factory stickers on the underside?
    GQ7227 likes this.
  20. May 20, 2019 at 7:53 AM
    RedManRocket
    Red
    2002 Double Cab LT
    I'm guessing it's just a mixture of engine heat cycles and paint neglect, pretty common
