Paint or replace?
Discussion in '1st Gen. Tacomas (1995-2004)' started by CraigMo, Jun 2, 2010.
  1. Jun 2, 2010 at 1:29 PM
    CraigMo
    CraigMo [OP] 2007 Tacoma PreRunner
    Bay Area, CA
    09 PreRunner
    So my front bumper cover is that faded grey color and I'm tempted to spray paint it black.....or should I just replace it?
  2. Jun 2, 2010 at 1:32 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    if you lightly go over it with a propane torch, it will blacken right back up.
    a little trick I learned from the jeep guys on how to bring back the black on the fender flairs. It will work on the black plastic flares too.
    I am not saying melt it, just lightly run the torch over it
    Justin
  3. Jun 2, 2010 at 1:35 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    i just painted mine actually today i used a can of flat black from osh and it looks good to me but if you have a torch laying around that would be cheaper a can of spray paint is only a few bucks
  4. Jun 2, 2010 at 1:42 PM
    CraigMo
    Bay Area, CA
    09 PreRunner
    Torching it, eh? Damn, never would have thought of that one.
  5. Jun 2, 2010 at 1:43 PM
    CraigMo
    Bay Area, CA
    09 PreRunner
    Pretty sure I can cover da cost of a can of spray paint...just wondering how well it will hold up.
  6. Jun 2, 2010 at 2:14 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    should hold up just fine just be sure to a good thick coat or a couple coats i think i used two cans if you are going to paint them just ruff them up a little bit with an sos pad that way the paint will stick better and it should hold fine also make sure to let it cure before you wash it
  7. Jun 3, 2010 at 12:04 AM
    mtucker
    mtucker Tacoma addict
    Escondido, CA.
    03 Prerunner DC
    Replaced chrome badges with Sockmonkey black badges, painted billet grill black, K&N cold air intake, my corner light turn signal circuit, Speedfreek traction bars, RAAMaudio BXT/Ensolite, Stereo: Kenwood KIV-701 USB/Bluetooth deck, 10" Pioneer shallow sub behind the rear seat, Infinity 6822cf 6x8 front and rear doors, Fosgate P400-2 (sub), US Acoustics USX-4065 (four main speakers)
    For $132 (list price of the bumper cover), I would paint it. The torch sounds fun. Krylon makes a plastic specific paint in flat, gloss, and satin black.
  8. Jun 3, 2010 at 6:47 AM
    My68ur8trd
    Justin
    Williamsburg, VA
  9. Jun 3, 2010 at 8:35 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    ^ Oh wow thank you! I'm going to do it now!
  10. Jun 3, 2010 at 8:39 AM
    Boosted17
    Boosted17 Well-Known Member
    Cliff
    Florence, Ky
    Looking for a new Toyota Truck.
    2006 Corvette Z51 M6. Best mod ever!
    X2! Thank you!
  11. Jun 3, 2010 at 9:07 AM
    gonathan85
    gonathan85 Well-Known Member
    Nate
    Central California
    '13 4x4 SR5 V6 Tacoma
    you can also take a shop rag, and a tube of some silicone gel...rub the gel into the plastic to restore....also helps water and junk to bead off....
  12. Jun 3, 2010 at 9:47 AM
    Madjik_Man
    Boulder, CO
    1998 Ext Cab 3.4 4x4 TRD 5MT sunfire red pearl
    About 25 pounds of spray paint and vinyl dye
    My fender flares are so chewed up from gravel/etc... it has the white filling(?) showing through in a lot of spots.
    Am I sh*t out of luck with trying to restore it via the heat gun method?
  13. Jun 3, 2010 at 9:51 AM
    gonathan85
    Nate
    Central California
    might recommend paint at this point?
  14. Jun 3, 2010 at 9:51 AM
    Madjik_Man
    Boulder, CO
    That's what I was thinking. Either that or using bedliner on it (if it doesn't look too cheap/cheesy)
  15. Jun 3, 2010 at 10:14 AM
    My68ur8trd
    Justin
    Williamsburg, VA
    take some before and after shots so we can see how it worked on the tacoma flares
    Justin
  16. Aug 16, 2010 at 8:19 AM
    iDigTulsa
    iDigTulsa Well-Known Member
    Luke
    Tulsa, OK
    03 DoubleCab TRD SR5 4x4
    Free Alarm Mod, Grey Wire Mod, Reverse Leaf Spring Helper Mod, Kenwood Deck, Memphis 10'', Yakima Roof Rack, Debadged Sides,Silver Toyota Skid Plate, Injen CIA, 3.5'' Amsoil Dry Filter, 17 x 7.5 Tundra Split Spoke Alloy's
    Maybe taking a torch to your truck scares the crap out of you. Maybe you are worried about the paint peeling off after you spend the entire weekend prepping and re-painting your flares. Maybe you don't want to drop your hard earned cash on a new set of flares to replace the old ones.
    Are you S.O.L.?
    Nope, check out the wonders of the Magic Eraser!
    A pack of four cost me about about $5.00, and this project took me all of about 10 minutes last night.
    Faded Grey Fender Flare BEFORE The Magic Eraser.
    Restored Black Fender Flare AFTER The Magic Eraser.
    The AFTER picture of the flare does not have any "store bought" shine enhancing product applied (Black Magic, Back to Black, 303 ect.). The Magic Eraser is slightly abrasive, and removes the built up wax and oxidation that causes our flares to become grey over time. It also worked wonders on my unpainted door handles and my "faded" lower bumper as well.
  17. Aug 16, 2010 at 8:47 AM
    flightcancled
    flightcancled Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Repp added!
  18. Aug 17, 2010 at 9:08 AM
    CraigMo
    Bay Area, CA
    09 PreRunner
    So where can we all buy this magic product?
  19. Aug 17, 2010 at 9:21 AM
    iDigTulsa
    Luke
    Tulsa, OK
    As someone posted earlier their girlfriend/wife had a few under the sink. If that search turns up nothing here are a few places that you can track them down. I purchased the Extra Power ones, that say they are 50% stronger, but I never used the original ones before so I honestly couldn't tell you if they lasted twice as long. I think they were about $1.75 more expensive...so still cheap.
    Wal-Mart
    http://www.walmart.com/ip/Mr-Clean-Extra-Power-Carton-Magic-Eraser-4-ct/14860463
    Amazon
    http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=magic+eraser&x=0&y=0&ih=2_0_0_0_0_0_0_1_0_1.135_105&fsc=1
    Lowes
    http://www.lowes.com/SearchCatalogDisplay?storeId=10151&langId=-1&catalogId=10051&N=0&newSearch=true&Ntt=magic+eraser&x=0&y=0
    Home Depot
    http://www.homedepot.com/webapp/wcs/stores/servlet/Search?keyword=magic+eraser&langId=-1&storeId=10051&catalogId=10053
  20. Aug 17, 2010 at 10:35 AM
    Madjik_Man
    Boulder, CO
    Dude.
    You f'in rock!
