Paint parts?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pinktaco808, Aug 20, 2021.
  1. Aug 20, 2021 at 4:00 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    What are the proper steps to painting the rear bumper end caps to colormatch? I know it plastic so what special primer used so it adhere better???
    I have the base paint and clear what else???
  2. Aug 20, 2021 at 4:04 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Bring it to a paint shop it'll save you future headaches, dollars, and finish will be better.
  3. Aug 20, 2021 at 4:05 PM
    pinktaco808
    I was quoted 200 just for the small part
  4. Aug 20, 2021 at 4:09 PM
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    Unless you have all of the spray equipment and knowledge to complete the job then yes $200 is a bit much. If you have to ask which primer to use then I'm going to assume this job will turn out semi-ok.
    I'm all for DIY but sometimes it's best to let the pros take care of certain things.
  5. Aug 20, 2021 at 4:22 PM
    pinktaco808
    It only a small part, I wanted to make sure. I painted parts before but not a lot of plastics... I know a 2 part adhesion promoter with primer, base color, and clear
    OriginalMan[QUOTED] likes this.
  6. Aug 20, 2021 at 4:36 PM
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    I used bulldog adhesion promoter on all plastic pieces, 2k primer, base, and clear. Color matching comes down on experience.
  7. Aug 20, 2021 at 10:45 PM
    pinktaco808
    How many coats base? What color? What you suggest for silver
  8. Aug 20, 2021 at 11:21 PM
    OriginalMan
    Oahu 808
    2017 TRD OR 4x4
    I cannot give you any recommendations. Check the paint code of your taco. I suggest you use plastic spray cards to figure out coating amount to match rest of your truck.
  9. Aug 21, 2021 at 5:18 AM
    MikeWa86
    MikeWa86 Member
    I'd 2nd calling around a few body shops/collision centers. $200 sounds a little steep for 2 pieces but it will be done right - and usually the work guaranteed to last as long as you own it. It was explained to me its the labor in the prep since a lot of these places are doing bigger repairs - your small pieces slow down their flow.
    I Paid $180 in MA for my '14 Accord sedan (Blue Pearl) mudguards to be done. 7 years later they look flawless. looking back it was worth spending the money.
    I paid probably $80 in supplies for a DIY on my '12 Civic (magnetic Gray) mud guards years ago. I used www.Automotivetouchup.com who color matched the paint, send me everything i needed. They came out FINE. i actually did a good job.
    if you trust your skills - or are at least confident in trying and are trying to save a few bucks, Id listen to the prep and steps posted by @OriginalMan and watch a few youtubes. You got this!
    pinktaco808[OP] likes this.
  10. Sep 22, 2021 at 4:53 PM
    pinktaco808
    Only one side
  11. Sep 22, 2021 at 5:26 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I'm gonna be the odd man out and say $200 bucks sounds like a good deal to avoid the hassle.
    This is coming from a guy that's done it, with a fished product that I'd call a success.
    It's gonna be $50~ bucks in product, before you even get after it with the labor.
    As with all things, it's all relative..
    Steves104x4 likes this.
  12. Sep 22, 2021 at 5:33 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    jmneill, StayinStock and Grossomotto like this.
  13. Sep 22, 2021 at 5:59 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Cheaper to vinyl wrap em ?
  14. Sep 22, 2021 at 8:19 PM
    pinktaco808
    Same color though the silver sky metallic???
  15. Sep 22, 2021 at 8:55 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    3M 1080 G120 Gloss White Aluminum is supposed to be really close.
  16. Sep 22, 2021 at 9:56 PM
    pinktaco808
    For the 2020 tacoma silver sky metallic? 1d6
  17. Sep 23, 2021 at 12:33 AM
    SouthernFried
    SouthernFried Well-Known Member
    South Carolina
    2020 TRD OR DCSB
    You outta keep it chrome. I have the painted bumper, and believe it or not…. I honestly almost prefer the look of the chrome ones.
