Paint problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kingfish 48, Dec 3, 2023.
  1. Dec 3, 2023 at 8:13 AM
    kingfish 48
    kingfish 48 [OP] New Member
    2013 ?Tacoma Gray
    Vehicle Modifications:
    I have repainted 3 panels on my 2013 gray Tocoma due to badly fading paint> top, hood, rear quarter panel. Is there a Toyota recall for this problem? The next move is to paint the entire truck.
  2. Dec 3, 2023 at 8:27 AM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    040 3rd gens from Mexico, yes. 2nd gen, no.
    Canadian Caber likes this.
  3. Dec 3, 2023 at 11:24 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    2015 MGM , truck is kept outside and I live in a salt state and no problems with paint. I do keep it washed , waxed and undercoated and no problems with the paint peeling or fading or the chassis rusting.
  4. Dec 3, 2023 at 11:30 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    All 2Gens parked outside in sun all the time have clear coat issues at some point - yes on all horizontal facing surfaces like hood, roof, top of flares, under the door windows and no TSB or recall except issues with the white and not sure what became of that but would guess not much. Full paint job with lifetime warranty around 8K base and clear and then my 09 was a real mess and I'm cheap so Maaco has it now and a single stage full paint with no big body work is costing me 2400. Rates run all over the cost spectrum so depends on what you want to pay and the quality you want - mine is 14 years old.
  5. Dec 3, 2023 at 5:34 PM
    inkmanmac
    inkmanmac Member
    Gerard
    New Jersey
    2007 Extended Cab 4x4 V6 Tacoma
    2.5" lift kit. Rear Air Bags, Snow Plow hook up,Stainless Steel Flex Brake hoses. Aftermarket Head unit, Off road lighting.
    I own a 2007, I have both clear coat and Top coat issues. The paint problem started in the door Jams (looked like there was and issue with adhesion between the Primer coat and top coat) that problem has now spread to the middle of the hood and top of the cabin.
  6. Dec 3, 2023 at 5:55 PM
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    My 040 second gen flaked like snow on a New England winter’s day. After being religiously cared for. Many others with the same problem.
  7. Dec 3, 2023 at 9:28 PM
    Steelhead Bum
    Mitchell
    Eastern WA
    Yep. Pretty well known problem for years now.
    Op asked if there was an open service campaign for fixing paint on 2nd gens, There’s not.
    There is a service campaign to correct paint on specific year 040 3rd gens made in Mexico.
    Not really sure what your point is.
  8. Dec 3, 2023 at 9:43 PM
    Sugar Silva
    Dave
    San Diego, CA
    Just not one to pass up an opportunity to bitch about it
