Paint shop won't touch my truck because of Fluid Film. Ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bit, May 5, 2020.
  1. May 5, 2020 at 3:18 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It sounds like a load to me also.
    You could also let the insurance company take care of getting it fixed to your satisfaction. After all that is what you pay them for.
    Maybe they will buy you a new truck without fluid film on it. :p
    Biscuits likes this.
  2. May 5, 2020 at 3:36 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^ the body shop's are nuts.
  3. May 5, 2020 at 3:48 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Anyone that’s done any serious paint work knows how many problems oil contamination can cause. Maybe it would be an issue maybe not but there is no way I would take a chance with my 100k paint booth not for one job.
  4. May 5, 2020 at 4:49 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    If it takes 2000+ psi power wash to remove fluid film how is a paint gun at 20 psi going to cause an issue?
    6 gearT444E and Jimmyh like this.
  5. May 5, 2020 at 5:21 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    I have no idea but that’s the point. There’s no way I’d be willing to find out for one small job.
  6. May 5, 2020 at 7:47 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    This!
  7. May 5, 2020 at 7:49 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I agree with the underlined part.
    How is painting a body panel on the shiny side of the truck going to have any effect on fluid film under the truck on the frame.
    I wonder if they paint cars with a slight transmission fluid leak or oil leak on the engine or differential. Right. They do it everyday. They are being stoopid. o_O
    Silentshredr likes this.
  8. May 5, 2020 at 8:03 PM
    BuschWacker
    BuschWacker Well-Known Member
    Calgary, Alberta
    2015 TRD Sport DCLB
    you are more or less correct. The rest of the vehicle is masked with paper and/or plastic, and the panels to be painted would be cleaned thoroughly and degreased before paint.
    armourall and the like are some of the absolutely worst things to introduce into Body shops, yet half the vehicles on the road are completely covered in the stuff. Shops don’t turn those cars away.
  9. May 6, 2020 at 6:08 AM
    $yoda$
    Tom
    2007 Tacoma 4.0
    And at your shop you could make that call and probably be fine. I would send him down the road to you and move on to the next one.
  10. May 6, 2020 at 2:51 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well bully for you. Are you saying that you would never paint a car with a slight transmission fluid leak or oil leak on the engine or differential?
    The fluid film is not an issue.
  11. May 6, 2020 at 3:26 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    No of course not but we aren’t talking about a slight leak it’s a vehicle with the entire undercarriage sprayed with refined petroleum and wax and having no idea what Problems if any it could cause. I just understand why he’s having trouble finding someone that is willing to try it and find out. I’m guessing you haven’t spent a lot time working with body shop guys and painters most of them are extremely picky about that kind of stuff.
  12. May 6, 2020 at 3:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Whatever. I disagree and we can leave it at that.
    Last time I painted a car it was using Lacquer...
    doublethebass likes this.
  13. May 6, 2020 at 3:35 PM
    BuschWacker
    Calgary, Alberta
    2015 TRD Sport DCLB
    I paint cars daily, and I never inspect the under carriage looking for potential hazards. Keep the surfaces clean that I’m painting, cover up the rest. Never had an issue in 15 years.
  14. May 6, 2020 at 5:32 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    Cool maybe you can call some of the places that turned down the op and talk them into it for him he would probably appreciate it
  15. May 7, 2020 at 5:38 PM
    #35
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
  16. May 31, 2020 at 10:37 AM
    #36
    Bit
    Bit [OP] Member
    1996 Silver Tacoma
    Thanks all. In talking with the place that refused to paint it, it became clear that they did so as 1) they were not familiar with Fluid Film and needed to do more research on it, and 2) they were a small company that could not take the risk. This was similar to other smaller shops. I then switched to larger shops and none of them had an issue. I ended taking it to a well established, large, family owned business where it is currently being worked on. Thanks for all the help.
    ChemDawg, redcon, SR-71A and 5 others like this.
  17. May 31, 2020 at 9:02 PM
    #37
    Jimmyh
    SC
    2012 Prerunner SR5
    Thanks for the update OP! It is good you located someone that isn't overly paranoid.
    6 gearT444E likes this.
  18. Jun 1, 2020 at 8:15 PM
    #38
    Steve_P
    Steve_P Well-Known Member
    TN
    09 Tacoma SR5 4WD 4cyl
    Regardless of the validity of the concern, I'm guessing you've never been in a downdraft paint booth. They will literally move your hair like a hurricane. It's not the paint gun it's the 30K CFM of air the booth moves. It's insane.
  19. Jun 1, 2020 at 8:30 PM
    #39
    BuschWacker
    Calgary, Alberta
    2015 TRD Sport DCLB
    ive been in the industry for a little over 20 years. I’ve worked in a handful of shops in that time. From brand new $300k booths to crappy run down booth, full down drafts, partial down drafts, and side draft booths. None of them Have moved my hair like a hurricane. You Don’t want the paint to get sucked down into the filters before it has a chance To even hit the vehicle.
  20. Jun 1, 2020 at 8:35 PM
    #40
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    if the dont want to spray Fluid Film
    they have their reasons
    recently there must be at least 40 polymer
    ceramic
    coatings retail
    diff shops wont bw able to spray
    match
    stand behind them all
    find a shop that does
    good luck
