Paint spill in bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, Apr 2, 2019.
  1. Apr 2, 2019 at 3:12 AM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Just had a quart can of valspar bonding primer spill in the bed. I think I got lucky because none of it made it to the tailgate and out to the paint, or to the drain holes in front. Wiped it up with a towel and got rid of the can. In the midst of the drive in to work, the can rolled in a turn and popped open.
    How do I clean this up without fucking up the truck? I assume this will never look the same. At least it is latex primer.
  2. Apr 2, 2019 at 3:21 AM
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    Try a power washer before it dries. I think there’s more of a chance since it’s latex and not oil based
    rmorse and lynyrd3 like this.
  3. Apr 2, 2019 at 3:25 AM
    UKJON
    UKJON Well-Known Member
    I agree, pressure washing should remove latex. At least it didn't happen on Monday....
    tcjacado likes this.
  4. Apr 2, 2019 at 3:28 AM
    CTtoNoVa
    Pop N Lock
    I’m thinking also if you have access to a hot faucet or mix valve, use warm water and put some dawn detergent down to help
  5. Apr 2, 2019 at 3:44 AM
    CTtoNoVa
    Pop N Lock
    If you go the pressure washer route, be mindful of the splashing of the ‘painty’ water if it goes out of the bed and onto the truck paint. Just rinse it immediately so it doesn’t cake on
  6. Apr 2, 2019 at 3:44 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Just got to work on base, there is one of those self serve car wash stations here so off I go, good suggestion, they have the power wash setting. I figure after that I will put paint thinner on it and use a stiff nylon brush. Didn’t want any runoff to screw up the truck paint though.
  7. Apr 2, 2019 at 3:47 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Yeah this is making me rethink the pressure washing....I can see some unintended consequences....I’ve wiped it up pretty well with the towel, think I will just leave it, scrape up what I can later and then go with paint thinner and brush after that.
  8. Apr 2, 2019 at 3:53 AM
    CTtoNoVa
    Pop N Lock
    Paint thinner won’t work on latex and will destroy your cars paint if it touches it. I would avoid that
    tcjacado, ChemDawg and TomTwo like this.
  9. Apr 2, 2019 at 3:55 AM
    CTtoNoVa
    Pop N Lock
    I would still do pressure washing. Just before you put the wand away do a pass on the car and you will be fine. Pair up with the nylon brush and scrub with soap and hit with water and keep alternating until it’s gone
    12TRDTacoma likes this.
  10. Apr 2, 2019 at 4:03 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    It's not going to all come off, have the bed floor rhino lined.
    It's much better anyways to keep stuff from sliding around.
  11. Apr 2, 2019 at 4:08 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I think my only concern other than aesthetics is what’s left transferring to anything I put in the bed. Why did it have to be primer dammit? Just plain latex paint would peel off like a dream most likely.
  12. Apr 2, 2019 at 4:09 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Is there any chemical at all I should use? Or just detergent and elbow grease.
  13. Apr 2, 2019 at 4:11 AM
    CTtoNoVa
    Pop N Lock
    I would start with soap and if it doesn’t work hit google for suggestions
  14. Apr 2, 2019 at 4:15 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Sub'd - I have some trace paint marks in the bed that I'd like to get rid of.
  15. Apr 2, 2019 at 4:22 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    You could try rubbing goof off or goo gone, but stay away from thinner or other solvents. Not good for plastic. I would bed line if it came to it
    TomTwo and SilverBulletII like this.
  16. Apr 2, 2019 at 4:26 AM
    96carboard
    96carboard Well-Known Member
    Paint *thinner* won't hurt paint that's already dried/hardened.
    But you are correct that it won't help with latex.
    OP: Flowing water, soap, scrub brush.
    If it leaves some, then there *may* be another option, but you have to be very careful with it;
    Paint *stripper* will be able to take off dried/hardened paint, HOWEVER, you will need to test it out on the bed surface to make sure that it doesn't actually eat the truck bed.
    If paint stripper can be used without harming the truck bed, then apply with a brush, then wipe it off with a cloth, do not let the stuff pour off the back of the truck since you will wreck the paint back there. Once its wiped off, then you use lots of dish soap and a scrub brush to wash off the paint stripper.
  17. Apr 2, 2019 at 4:36 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    Try denatured alcohol to soften it up. Then use a plastic scraper.
    SilverBulletII likes this.
  18. Apr 2, 2019 at 4:45 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Scrub with the hottest water you can stand. Use a little Dawn dish soap too. Anything left, hit with some Purple Power, Simple Green, Super Clean etc. Keep it wet, don't let it dry. Scrub more if needed. Hot water is your friend. Being latex, I'd be very surprised if any trace remains.
  19. Apr 2, 2019 at 4:56 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
  20. Apr 2, 2019 at 4:56 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Buy a bed mat. Out of sight, out of mind.
    TheRealKrobar, TomTwo and Muddinfun like this.
