Paint stripper on tires
Discussion in '1st Gen. Tacomas (1995-2004)' started by farmer_kyle, Sep 13, 2016.
  1. Sep 13, 2016 at 9:31 AM
    farmer_kyle
    farmer_kyle [OP] Well-Known Member
    2004 Tacoma sr5
    3.5" (adjusted to 4.5") fabtech suspension lift. 15x8 procomp 252 crawlers. 32x11.5 BFG Ko2's.
    Hey guys I painted the lip of my rims for a "beadlock look". I'm going to use paint stripper to get the spray paint off but if the paint stripper gets on my tires, will they fade the black rubber? I'm removing the white spray paint off of pro comp powder coated black rims. Any help would be greatly appreciated. Thanks
  2. Sep 13, 2016 at 9:40 AM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    I would not get paint stripper on tires. I'd be concerned it would soften the rubber, however I haven't tried it.
  3. Sep 13, 2016 at 8:39 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Skip the paint stripper. Use a tiny bit of acetone on a rag. The acetone will remove the spray paint easily. Can't emphasize how little to use. Too much acetone will eat the rubber too though so be careful, but it'll be less aggressive than the stripper.
  4. Sep 13, 2016 at 8:50 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Or you could just mask the tires off and not have to worry about overspray..
  5. Sep 14, 2016 at 4:20 AM
    Indy
    Indy Master of all I survey.
    10 minutes spent masking saves hours of cleanup.
    Rmodel65 likes this.
  6. Oct 3, 2016 at 12:13 PM
    farmer_kyle
    2004 Tacoma sr5
    My rims are already powder coated black. Will this take off the white spray paint on them without fading the powder coat?
  7. Oct 3, 2016 at 2:32 PM
    Rmodel65
    Jawja
    1996 Yota 4x4
    Viper Red paint
    no it will probably mess them up..i used to powercoat and we would use acetone and powder to touch up the places where the parts where hanging by the wire..id try a little buffing compound and if that didnt work id try a little lacquer thiner
