Paint Wrinkles on 2nd Coat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Apr 19, 2022.
  1. Apr 20, 2022 at 11:14 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Short answer: Yes.
  2. Apr 20, 2022 at 12:15 PM
    TacoTimbo
    TacoTimbo Well-Known Member
    South Denver
    2015 Tacoma TRD
    You got it. Even a brand new truck with perfect paint would need sanding.
    wi_taco likes this.
  3. Apr 20, 2022 at 12:18 PM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    My world is rocked who knew you couldnt spray new paint directly onto the clear coat I demand a recount ! Lol
  4. Apr 20, 2022 at 3:36 PM
    TacoTimbo
    South Denver
    2015 Tacoma TRD
    photogr4x4 likes this.
  5. Apr 20, 2022 at 7:30 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Well he said in his post: Sprayed with highly diluted spic and span and wiped and dried off the area before applying 2nd coat.
    TnShooter likes this.
  6. Apr 24, 2022 at 6:14 PM
    TacoBell07
    Four door 2wd Taco
    Do you usually spray mineral spirits onto paint just before spraying new paint ive been using apple cidar vinegar diluted with water but Im not sure its working well. THis is after I 320, 400, and then 600 grit sanded the clear coat surface before attempting to add a new coat of paint.
  7. Apr 24, 2022 at 7:38 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I think you are trolling now.
    That is insane.
    wi_taco, wilcam47 and Monkeybutt2000 like this.
  8. Apr 24, 2022 at 8:08 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Jimmyh likes this.
  9. Apr 25, 2022 at 7:45 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    I've had spotty performance issues with Rustoleum spray paints recently with non-automotive projects. Usually, with extremely long dry times, a day or better and have put some small parts in the home oven at low temperature to get them to dry. I'd seriously think twice before ever using Rustoleum on automotive painted sheet metal surfaces. For automotive painted sheet metal I stick with one of the automotive canned spray paints.
  10. Apr 26, 2022 at 7:52 PM
    TacoBell07
    Four door 2wd Taco
    I sanded the faded factory paint with 320, 400, then 600 then spray painted with Rustoleum automotive enamel. Paint seems to run alot and places appear in circle almost like a bubble where it didn't stick to the metal at all. and cans spit drops half the time its really ridiculous.
    Is this just rustoleum i mean its automotive enamel not just regular Rustoleum, Im not sure what Im doing wrong.
  11. Apr 27, 2022 at 3:45 AM
    Too Stroked
    Tom
    Did you do a solvent wipe and tack rag wipe before applying the primer, then paint? Surface contaminates will cause what is called fish eying.
  12. Apr 27, 2022 at 7:25 AM
    dtaco10
    Dave
    The plant I worked at removed all spray lubricates that contained silicone from the assembly areas because they claimed it caused fish eyes in the spray booths even though parts went through a cleaning tank.
    Too Stroked[QUOTED] likes this.
  13. Apr 27, 2022 at 7:49 AM
    TacoTimbo
    South Denver
    2015 Tacoma TRD
    Silicone and spray paint are mortal enemies. They can not coexist in any environment.
    Too Stroked likes this.
  14. Apr 27, 2022 at 8:46 AM
    TacoBell07
    Four door 2wd Taco
    I after sanding 320, then 400 grits i wiped it down with mineral spirits. Did not use a tac cloth though. I used to wax the car a ton but this panel the paint is not that faded so im not sure how wax would contaminate the surface if I sanded it first.
    I did not apply primer to this panel before adding the automotive enamel but I may try that today.
    I would use a spray gun from harbor freight but if I cannot stop the runs and catfish then I dont want to go to all trouble to set up a spray gun.
    ALso keep having issues with the spray paint dipping then spraying the drips all over making it similar to runs but thats a separate issue.
    I guess I just thought that if you have factory paint thats good sand it 400 or so then apply the new coat of paint but that doesnt seem to work.
  15. Apr 27, 2022 at 7:53 PM
    #35
    Jimmyh
    SC
    2012 Prerunner SR5
    I know someone that needs to hire a professional.
    :cool:
  16. Apr 28, 2022 at 3:40 AM
    #36
    TnShooter
    Deogee
    STOCK
    If it were that easy, body work would not be as expensive as it is.
    You’re finding out first hand why a good body/paint guy charges what they do.
    Humidity alone can make it hard lay paint. Let alone getting everything else right.
  17. Apr 28, 2022 at 3:55 AM
    #37
    photogr4x4
    photogr4x4 Well-Known Member
    Canada
    TRD OR
    Nada
    A lot of Rustoleum rattle cans explicitly state "Not For Automotive Work" on the cans. I bought a can to coat some banged up rocker panels and read it thoroughly. Kept it around because I'd probably need it for some else eventually. Now I'm using it to fix some gouged powdercoating on bed stiffeners that I bought that the manufacturer didn't want to replace due to defects, stating it was a shipping issue. You'd think they would insure their shipments? :confused:
  18. Apr 29, 2022 at 9:36 AM
    #38
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
