painted my wheels
Discussion in 'Wheels & Tires' started by astartech, Mar 6, 2009.
  1. Mar 6, 2009 at 1:59 PM
    astartech
    astartech [OP] Member
    southern california
    06 prerunner TRD sport
    Bilstien adjustable height front struts
    I was inspired by some of the members that had painted their wheels black. I love my new $25 wheels!
  2. Mar 6, 2009 at 2:00 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
  3. Mar 6, 2009 at 2:00 PM
    bradu81
    bradu81 Well-Known Member
    N. California
    Silver Dbl Cab 4x4
    Looks Good !!:cheers:
  4. Mar 6, 2009 at 2:02 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    saweeet!
  5. Mar 6, 2009 at 2:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    Makes me jealous-It's cheap to paint rims....Buying new rubber is expensive...and your tires look AMAZING with those blacked out rims...
  6. Mar 6, 2009 at 2:10 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    looks like were starting a trend, niiiice
  7. Mar 6, 2009 at 2:36 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah those look sweet!!! Good job!!:D
  8. Mar 6, 2009 at 3:45 PM
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 tundra crewmax trd
    tacoma sold 11/13/13 Not much on Tundra yet, just Husky Weatherbeaters front and back
    they look good!
  9. Mar 6, 2009 at 3:48 PM
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    Very nice! What paint product did you use?
  10. Mar 6, 2009 at 3:57 PM
    KMADA
    KMADA Well-Known Member
    Long Beach, CA
    08 prerunner trd sport
    15% tint, 6k HIDs, K&N intake
    Lemme know how they keep up like if it chips or anything. Because I was thinking about getting it powdercoated or just paintin them also.
  11. Mar 6, 2009 at 4:01 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    Excellent nice work.
  12. Mar 6, 2009 at 9:07 PM
    Brunes
    Brunes abides.
    Rotorhead
    I've had mine painted since August and the only issues I've had is some light rash after a day of moderate to hard wheeling.
    I used Duplicolor regular Satin paint with Duplicolor Sandable Primer. Total...about 25 bucks and about 3-4 hours work over a weekend.
    Powdercoat will prolly run you in the neighborhood of 300-500 for all 4 rims. It might last better- but if you do damage it-The whole wheel has to be redone as opposed to just touching it up with a spray can.
    TONS of threads about how to prep, prime, and paint- totally worth it-The satisfaction is awesome and the look is great too!!
  13. Mar 6, 2009 at 9:07 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
  14. Mar 6, 2009 at 9:19 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Good job
  15. Mar 6, 2009 at 9:46 PM
    KMADA
    Long Beach, CA
    Yea I might as well spray can it. Because I'm not gonna wheel hard enough for and chips or anything. I just needa make sure I find the proper thread to teach me step by step
  16. Mar 6, 2009 at 9:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    I sent this to another member via PM a while back but here goes:
    I've posted tid-bits all over the place- but here is the summary:
    Jacked the rear end of the truck up- Removed both wheels. Used Maquire's Wheel Cleaner and some good car soap to scrub off brake dust.
    Dried them and sanded with 800 grit until all of the finish was roughed up....It'll turn white and you'll see the scoring. Wiped it down with alcohol. Then taped off the rubber.
    I used Duplicolor Sandable primer to fill some light scratches from where they removed the wheel weights. 2 coats- Front and inside the wheel. I spot sanded between. When you use spray paint you want the solvent to "flash off" before you add another coat- Depending on the weather and what not...takes about 15-20 mins.
    Then I used Duplicolor Satin Black paint (the wheel paint didn't come in satin). I did 2 coats of that as well...No sanding between. I let them dry in the house overnight...Put them back on the truck and took the front end apart and did the same thing. I had about 4 cans of each primer and paint- But I was working on the wheels and my grill at the same time...so you might not need that much.
    Cleaning them well and sanding well is important..
    The whole process will take you a whole weekend, but it's totally worth it. If you don't clean or sand well the paint won't adhere. If you rush the separate coats- The paint can bubble after it dries. Duplicolor is great paint. I've had those since March and I had no scratches on them any worse than normal wear-until I took it off roading- and even then there was only minor rash.
    If you are thinking about painting your brake calipers, or drums or doing any other suspension type work-This is a great time to do it while the wheels are drying.
    Good luck with it-If you've got any other questions- Hit me up!!!
  17. Mar 7, 2009 at 6:35 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2009 DC V6 TRDsport
    5100's all around - fronts at 1.75", 265/70/17 Bridgestone Revo 2, HID headlights and fog lights, factory skid plate, ss exhaust tip, tube steps, Access roll-up tonneau cover, Redline hood struts, 6 D-rings, seat MagLite, LED dome, fumoto oil drain, DTRL, fog light anytime, Kenwood/Clarion speakers, Pop-N-Lock 5300, LED bed lights and a few other things...
    Thanks for the write-up. I may do this as well.
  18. Mar 7, 2009 at 8:16 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    yeap just did mine last night.i think they look sweet.same with the grill surround.
  19. Mar 7, 2009 at 10:40 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Brunes, good job. I'm assuming the process will work with steelies, too? It's going to be a while before I get new rims (unless I find a deal I cannot pass on) and I am de-chroming as much as I can and going black (and I'll never go back). I'm also getting the Westin tubes LineX'd and possibly the rear bumper so black wheels will go well, I think.
  20. Mar 7, 2009 at 10:45 AM
    Brunes
    Brunes abides.
    Rotorhead
    I don't see what it wouldn't work with steelies- I don't know that those are coated or anything- So you might be able to wash, alcohol rub, and prime them. Sand them if the paint beads or bubbles and then re-alcohol wipe them and try again.
