painted the stereo and dash
Discussion in '2nd Gen. Tacomas (2005-2015)' started by colinb17, Jan 28, 2009.
  1. Jan 28, 2009 at 12:10 PM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    went a little paint crazy...what do you think?
    i used an all-purpose plastic and metal spray paint from duplicolor...a couple coats later, and it matches the speedway blue almost perfectly.
  2. Jan 28, 2009 at 12:20 PM
    AK27
    AK27 Well-Known Member
    that is friggin' sweet! nice work, looks good!
  3. Jan 28, 2009 at 12:22 PM
    Anthony999
    Anthony999 Well-Known Member
    Glendale, AZ
    05 Tacoma
    MB Seven X Wheels, Hankook Optima Tires, Billet Grille, Blacked out headlights tailights and third brake light, LEER 700 Series tonneau cover, Blacked out emblems, Wolo air horn, Sony Xplod stereo, 8" Bazooka subwoofer, painted to match bumpers, leather arm rests.
    Looks really good man. Did you take off the stereos faceplate to paint it? Or did you just tape off the buttons
  4. Jan 28, 2009 at 12:25 PM
    taco084gb
    taco084gb No matter where you go there you are.
    Galen
    NorCal
    Thats a great idea. That is why I had liked what the FJs did, something similar. Not 4sure if it would look good on mine since its white. The blue is awesome though.:D
  5. Jan 28, 2009 at 12:27 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i took everything appart...i took out all of the buttons and taped off the holes so the paint wouldn't make the fit too tight when i put them back in. the hardest part to take off was the piece that holds the air vents and the 4x4 switch. you havce to take out the two screws right above the spedometer becasue it actually hooks behind that part.
  6. Jan 28, 2009 at 12:33 PM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Ya dude. That is sick looking! I want to do that to my SWB now!
    :thumbsup:
  7. Jan 28, 2009 at 12:35 PM
    MSteinhauer
    MSteinhauer Well-Known Member
    Redondo Beach, CA
    09 4x4 DoubleCab SR5
    Nice clean mod. Good job!
  8. Jan 28, 2009 at 12:38 PM
    mpreiss
    mpreiss Attack Life.
    Capon Bridge, WV
    07 D.cab 4x4 w/3" Lift
    3" Pro comp Suspension Lift Fog light Mod. Tinted Front windows 15% (match rears) Tonneau cover Halo head lights K&N filter.
    Looks really good. Def. looks like it took some time to tape everything up so nicely. :thumbsup:
  9. Jan 28, 2009 at 12:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Looks great.
  10. Jan 28, 2009 at 12:42 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    2018 GMC Sierra SLT Z71 4x4... Yeah yeah, I know.
    Looks awesome. You should paint the A/C dials, too, if you can tape-off just the triangle where light comes through. I think it'd be badass to have SWB dials instead of black.
  11. Jan 28, 2009 at 12:47 PM
    Anthony999
    Glendale, AZ
    05 Tacoma
    I may have to do this now. I say this should go under cheap/free mods.
  12. Jan 28, 2009 at 12:50 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i thought about doing that, but for the same reasons i didn't paint the buttons (asside from silver accents looking good) is becasue i was afraid with all of the touching they get, that the paint would rub off.i'm still considdering it though. i'll see how well the rest of it holds up and go from there.
  13. Jan 28, 2009 at 12:52 PM
    mws4ua
    Birmingham
    I didn't think about that... You're probably right. Good call.
  14. Jan 28, 2009 at 12:54 PM
    harshest
    harshest I am the Sofa King
    Michigan
    05 PreRunner SR5
    Fog Light On, Hidden Garage Door Opener, Scanguage II, Weathertech Liners, Cig lighter always on, Door buzzer removed from dash- Upcoming: 5100s for front and rear, set fronts to 2.5" and Toytec AALs.
    Good job, not my cup of tea but it looks like you did quality work, which I can respect.
  15. Jan 28, 2009 at 1:11 PM
    robi0024
    robi0024 Well-Known Member
    WA
    21 Double Cab TRD Off-Road
    That looks professionally done. Great job!
  16. Jan 28, 2009 at 1:29 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Awesome! Come do mine!
  17. Jan 28, 2009 at 1:39 PM
    LDrider
    LDrider Well-Known Member
    New England
    2019 SR 2.7 Access Cab 4x4 (sold to Carvana!)
    I think you did a really nice job. Personally, I would probably get sick of it in about two days....To each his own, but you did some nice work.
  18. Jan 28, 2009 at 2:01 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    as I was reading I though, "no way will this look good." But Then I proceded to take a gander and I love it! Really good job!
  19. Jan 28, 2009 at 2:11 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    thanks for all of the feedback guys. i was nervous about how it would turn out and what people would think about it, but now i'm glad i took the risk
    that's actually what gave me the idea. i test drove an FJ, and really like the color matched faceplate.
  20. Jan 28, 2009 at 2:15 PM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    not my style but sure looks nice. awesome custom work :thumbsup:
