Painted Windows
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjclemen, Jun 20, 2011.
  1. Jun 20, 2011 at 12:19 PM
    rjclemen
    rjclemen [OP] Well-Known Member
    Riley
    Charlotte, NC
    07 Pre Runner The good looking Blue
    Tint, Bed Cover, HIDs, stubby antenna, double din system, debagded, All Terrain bedside stickers.
    Title says it all. My truck was covered in a fine mist of white exterior building paint. The paint is not noticable on the paint but the tinted windows look pretty bad. I have placed a claim on the damage through the painters and hopefully will recieve a check for repairs then just do it myself. Could I just use a razor blade and be super careful to get this paint off? What options do I have for removal?
    Thanks,
    R
  2. Jun 20, 2011 at 12:22 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    Only use razor on glass.just finger nail fuck all the paint spots on paint.a good body shop could wet send and polish the whole truck
  3. Jun 20, 2011 at 12:24 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Get a spray can of carb cleaner, should get it right off..
  4. Jun 20, 2011 at 12:25 PM
    shane100700
    shane100700 Look'n like a fool with your pants on the ground..
    Fort Dix, NJ (MT born and raised)
    08 Off Road, DC
    Kenwood 6140 w/nav/BlueTooth/backup cam/ Focal Components/ Alpine PDX-5/ JL 10", rear storage lock mod, tint, Snug Top xtra vision, OEM running boards, XD Spy 18x9, Nitto Terra Gripper AT's, AFE pro dry, Ultra Gauge
    You say there it doesnt show on paint and make it sound like your concern is the windows. So I have to ask, is the paint on the inside or something?! Windows are tinted from the inside so unless the paint got on the inside there would be no issues using a razor blade to get paint off the outside of the windows.
  5. Jun 20, 2011 at 12:25 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    claybar should work pretty good for removing most if not all of the paint. I have used brake parts cleaner to remove road striping paint from the lower portion of a customer's truck but that's extreme. I would assume the paint is water based so cleanup should be pretty straightforward.
  6. Jun 20, 2011 at 12:30 PM
    97Blk_one
    97Blk_one Well-Known Member
    Memfrica
    not so low
    A whole lot,But not satify
    What happen ? You parked where they paint?
  7. Jun 20, 2011 at 12:31 PM
    rjclemen
    Riley
    Charlotte, NC
    Yeah the paint that's is on the actual body paint isn't that noticeable. But the tinted windows look rough. Carb cleaner works well then? Might try that route.
  8. Jun 20, 2011 at 12:32 PM
    rjclemen
    Riley
    Charlotte, NC
    No when they were painting my office building they "accidentally" over-sprayed the parking lot and damaged like 10 cars.
  9. Jun 20, 2011 at 12:34 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    If you go that route, make sure you clean the carb cleaner off well and re-apply some wax. Carb cleaner will completely strip everything from the vehicle's clear coat.
  10. Jun 20, 2011 at 12:35 PM
    shane100700
    08 Off Road, DC
    There is no tint on the outside of your windows. Its all stuck to the inside of the windows. You can use a razor blade on any part of the "outside glass" for paint. Paint is what most dealers use on car windows when they advertise and dont use a carboard type sign. At the end they simply scrape it off with a razor blade. The dryer you keep the glass the less mess you will have to clean up when it comes to paint on the "outside" of the windows.
  11. Jun 20, 2011 at 12:37 PM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    i'm not a professional by any means, but i would go with a clay bar. it would work perfect and seems less harsh than using carb cleaner. either way, you will want to do a wax coat to protect the clear-coat.
  12. Jun 20, 2011 at 12:49 PM
    rjclemen
    Riley
    Charlotte, NC
    I do not plan on using the carb cleaner on the paint just the windows. I will clay bar the paint when I have time. I just want to clean up these windows ASAP.
  13. Jun 20, 2011 at 1:15 PM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    gotcha. yeah that makes sense. clay bar works very well on windows too, just fyi.
  14. Jun 20, 2011 at 1:23 PM
    97Blk_one
    Memfrica
    not so low
    Dang... Those painters need to pay up. I hope they insured and bonded. Sorry to hear that. Hope everything turn out for you.Good luck
  15. Jun 20, 2011 at 1:29 PM
    TacomaPrime
    TacomaPrime Cybertronian Tacoma
    Greg
    Illinois
    05 Prerunner SR5 TRD off road
    Claybar FTW!
  16. Jun 20, 2011 at 1:58 PM
    Paul's TRD
    Paul's TRD I'm Not Your F***ing Brother
    TX
    2011 Z71 4x4 5.3L V8
    Total that bitch out and then go find the guy who oversprayed and punch his fucking lights out.
  17. Jun 20, 2011 at 2:05 PM
    PeteH
    PeteH Well-Known Member
    I would make the painters fix their mistake. They damaged your property, why should you go through the effort and expense to fix their mistake?
    They carry expensive insurance just for these types of situations. If you want to fix it yourself, get an estimate and and keep the insurance check to offset your materials cost and labor.
    just my .02
  18. Jun 20, 2011 at 8:38 PM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Clay bar will get it off.
  19. Jun 20, 2011 at 9:39 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails WANT: Rear Plate Bumper, RokBlokz mud flaps, Steel bed cage
    +1
  20. Jun 20, 2011 at 9:43 PM
    neoflex
    neoflex Well-Known Member
    I think that is why he was asking. I believe he is looking to do the work himself so he can pocket the Insurance check.
