Painting a mdf sub box
Discussion in 'Audio & Video' started by chrispy, Feb 25, 2013.
  1. Feb 25, 2013 at 6:32 PM
    chrispy
    chrispy [OP] Well-Known Member
    Winnipeg, Manitoba
    2012 Tacoma SR5 4X4
    Hello, does anyone have steps on how to paint mdf subboxes, my idea is to paint it the same grey interior of the truck, but have a high gloss finish to it. From what i've heard is MDF is hard to paint. so i'm looking for step by step details on how to paint it and tips/tricks.
    Does anyone have pictures of their finished boxes that they have painted.
  2. Feb 25, 2013 at 6:39 PM
    Gimmick
    Gimmick Well-Known Member
    Anthony
    Canada
    2017 TRD Offroad DCSB
    Mdf is not hard to paint at all. Im a decorative painter/artist, and am constantly working with mdf. Its all prep though.
    Prime your piece. Latex or oil..either way. Latex will be a lot quicker
    Sand it. 220 sandpaper or a medium grit sponge.
    Repeat until you cant see the mdf. 2 coats usually.
    And youre basically ready for whatever paint finish you want to have. An oil based urethane is probablly a good idea to seal it once its finished. Itll put up with a bit of damage.
  3. Feb 25, 2013 at 6:44 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    The end grain sucks up alot of paint, thats why mdf is hard to paint. I wrapped mine in carpet, you can buy carpet specifically made for doing stuff like this, its really easy to work with and comes out great if you go that route. I made a box for my buddy, he sprayed it and he said it took like 7 coats lol
  4. Feb 25, 2013 at 6:58 PM
    chrispy
    Winnipeg, Manitoba
    2012 Tacoma SR5 4X4
    Thanks, ya i heard the end grain can absorb alot of the paint, but some people recommend putting a layer of bondo or wood filler to prevent this? since i would be filling in the screw holes in the prep stage this wouldn't be hard to do.
  5. Feb 25, 2013 at 7:05 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    Ya that would probably help and save you a couple coats, it looks like Gimmick is suggesting rolling or bushing on a primer. I bet if you did that it wouldn't take many coats, then maybe sand like he suggested then spray it
  6. Feb 25, 2013 at 7:47 PM
    sparks772
    sparks772 Member
    I just did my mdf enclosure with the 10 dollar can of rust oleum bed liner stuff, but i did a rust oleum primer till it quit soaking in where it looks like it wants to stay wet. Then i did the liner stuff till the can was almost empty about 3 coats, turned out good i should have let it dry a little more but not bad imo.
  7. Feb 25, 2013 at 8:06 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Gimmick is right; the prep is 99.999% of the battle when painting MDF.
    The best way to do it is to spray it down with an epoxy based primer like Slick Sand from Evercoat. That's THE best thing I've ever used when painting MDF cabinets. Most people use Latex primer not because it's better but because it's easier to come by. Problem is latex primers generally don't do well when you try and sand them.
    However, when the good stuff is hard to find there's another way. I learned a secret a few years ago that does an EXCELLENT job. Mix up a 50/50 mixture of Shellac and Alcohol and spray or roll that on generously. It will get soaked up by the MDF very quickly. When this dries it will cause the endgrain to firm up since it's impregnated with the Shellac. The surface will sand very easily after that.
  8. Feb 25, 2013 at 8:19 PM
    thelivestone
    thelivestone Well-Known Member
    paul
    Cape Canaveral, FL
    2017 Crewmax
    stock for now
    grey carpet is the way I went. I had a buddy help me. its like wrapping a present. and the carpet kinda prevents the edges of the box from damaging the truck when I take it out.
    just my 2 cents
  9. Feb 25, 2013 at 8:49 PM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    I have built many cabinets out of MDF (not particle board). If you have good clean cuts then block sand it to about 220 grit without rounding over the edges (unless you are after rounded over edges, in which case I use a router with a corner rounding bit). Anyway you have your box or cabinet looking sharp now, So blow all the loose dust off it and when the dust settles I brush on a liberal coat of minwax brand polyurethane (other brands work fine but do not dry as fast). When this coat is fully dry (2 days in a dry climate), sand it lightly with the 220 grit again to knock off the "fuzz" that is raised and the runs probably made (has to be fully dry!). Wipe it down with a damp cloth, then brush on a second coat carefully with a good brush. Once this is hard you will have the cabinet really sealed and you can paint it with anything you like. I sometimes go to 4 coats and leave it natural color for my hi-fi development boxes. Wife stays out of my basment listening room and I like the look actually.
  10. Feb 25, 2013 at 11:18 PM
    scalfee90
    scalfee90 Well-Known Member
    Shane
    Sylacauga, AL
    1999 Tacoma Manual 3.4L
    Custom skid plate, rock rails, front bumper & rear bumper, pioneer head unit with 3-way pioneer components, blinker mod, Eibach coils, Bilstein 5100s, Procomp AALs, American Racing Sawblades, M/Ts, BPV Bracket, deckplate, LED Dash
    Bedline it!
