Painting ARE CX with windoors
Discussion in 'Tonneau Covers, Caps and Shells' started by Hookedup, Jun 25, 2019.
  1. Jun 25, 2019 at 4:18 PM
    Hookedup
    Hookedup [OP] Well-Known Member
    SOFLO
    2012 DCSB SPORT/ 2019 OR DCSB
    FOX 2.5 DSC/ICON RXT/SPC UCA
    Hey guys, I found a used 3mo old ARE CX classic with slider windoors plus light strips & yak rack for 1,300$, i priced one new with all the same gimmicks for almost 2,800$. Now i just need to see some pics of how the windoors are mounted to see if i can remove them to paint it.. it’s in Voodoo blue. I need to get it painted cement. My friend owns a body shop so i can get a deal on the paint. You think it’s worth it?
  2. Jun 26, 2019 at 6:14 AM
    danielsthomas57
    danielsthomas57 Well-Known Member
    Thomas
    Virginia
    2013 Super White TRD Sport DCLB
    5100s, OME 887 and 1/4" pacer, 285/75/17s
    yeah its worth it depending how much he will charge you for the paint job. You could Vinyl wrap it.
  3. Jun 26, 2019 at 6:24 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I've removed all of my windows to reseal them. There's a bunch of screws on the inside that you need to remove. There are two trim pieces that when screwed together pinch the window in place. You can do it by yourself since the outer part will be held in place by the compressed weather strip, but it would be good to have a 2nd person holding it from the outside while you do the inside.
    You can remove the back flip up window too, but it is rivited in place and they need to be drilled out. Might not be worth going that far, but if you do you can bring it to a ARE shop and they'll re-rivit it back. Probably cost you $50. Maybe call and ask before you go that far.
    synaps3 and Hookedup[OP] like this.
  4. Jun 26, 2019 at 9:05 AM
    Hookedup
    SOFLO
    500ish give or take for paint
  5. Jun 26, 2019 at 9:50 AM
    danielsthomas57
    Thomas
    Virginia
    go with that!!! not a bad price.
