Painting base model grille...EPIC FAIL.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Priddle, Jul 30, 2011.
  1. Jul 30, 2011 at 6:39 PM
    Priddle
    Priddle [OP] And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    I found a use base model grille that I wanted to paint to match my truck. I was following instructions somewhere on TW that required adhesion promoter. I couldn't find any so I tried Kylon Fusion as the primer.
    I washed, dried, and wet-sanded the grille with 220 grit sandpaper. I then used rubbing alcohol to make sure it was clean. Once dried off, I applied 3-4 coats of Krylon as per instructions on can. An hour after the last coat, I applied the Dupli-color paint. During the 4th coat, the bottom of the can accidently hit the grille and took a spot of paint off. I could tell it wasn't dry, it was grimey. I knew that wasn't right and pissed off as I was, I took my thumb and smeared the paint right off the Krylon. It wasn't easy but it came off. See the last pic. I left it for an hour or so and came back. The black Krylon had dried and the color paint also seemed to be more durable. 'Perhaps I didn't give it enough time?' I thought.I figured I sand the black area that met the paint to perhaps apply Krylon again but later realized I could still use my fingernail to scrape the paint right off.
    My plan now is to try and sand it right down to the plastic again :frusty:, find some adhesion promoter, apply sandable primer then paint.
    Thoughts? Any suggestions on getting that paint off quickly? It still seems gooey underneath the paint.
    I did read that the Krylon was paintable but it doesn't appear to be. :facepalm:
  2. Jul 30, 2011 at 6:45 PM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    It probably diet have enough time to cure. And possibly you laid the paint on too thick?
    Just suggestions. Next time try to do even and lighter coats.
  3. Jul 30, 2011 at 6:56 PM
    04LTtacoma
    04LTtacoma Well-Known Member
    Outer Space
    x2. Next time spray the grill in the sun that way it will dry quicker after you spray the paint to the grill.
  4. Jul 30, 2011 at 7:02 PM
    KevMc
    KevMc Well-Known Member
    Kevin
    West Columbia, SC
    06 TRD Sport DC LB
    Satoshi with Hella 500FF's Readylift N-Fab Rear Runner w/ Westin lights TRD Seat Covers
    Best thing you can do at this point is let the paint sit and cure out as much as it can, so that it hardens up some and won't be such a pain to sand off.
    You did a good job scuffing the grill but spray can stuff just won't get you the finish you're looking for. Duplicolor over Krylon probably didn't jive.
  5. Jul 30, 2011 at 7:07 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    I second that. I was goin to say that maybe the paints didnt mesh well. When I was painting my lower valance. I used a cheap paint to cover it. Then I used the krylon clear coat and something in it peeled the base coat off. It sucked.
  6. Jul 30, 2011 at 7:13 PM
    Priddle
    Thanks for the replies. I did paint it in the sun (although it was mostly cloudy) but it is likely I rushed the process and/or didn't use the proper process.
    The finish of the paint seemed promising though.
    I was using this thread as a reference but obviously didn't follow it 100%. But this guy had good results.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/117163-painting-grille.html
    I was trying to find the Dupli-color adhesion promotor at Canadian Tire but they are not stocking it. Napa may carry another brand so I'm trying them tomorrow.
  7. Jul 30, 2011 at 7:25 PM
    Joben7726
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    Almost any auto store should have adhesion promoter. Self etching primer is a good one to use. Try to use plastic paint as well as matching paint brands if possible.
  8. Jul 30, 2011 at 7:28 PM
    KevMc
    Kevin
    West Columbia, SC
    06 TRD Sport DC LB
    See if you can find Bulldog, it's good adhesion promoter out of a rattle can.
  9. Jul 30, 2011 at 8:09 PM
    Priddle
    Ok. Thanks for the tips!
  10. Jul 30, 2011 at 9:45 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Goo gone will take off the fresh paint pretty easy if you want to go back to square one. Otherwise, like mentioned let it dry up enough to sand and re cover.
  11. Jul 30, 2011 at 9:51 PM
    TaCoLoCo®
    TaCoLoCo® conquistador
    Dave
    Euless TX
    2006 Tacoma DC TRD Prerunner
    Just buy the grille color matched from usatoyotaparts.com, I'm lucky to live close to pick one up. $190.00
  12. Jul 31, 2011 at 4:43 AM
    Priddle
    I saw that site before and checked again but they don't have DSM colored grilles. Its not a popular color so I guess they don't bother with it.
  13. Jul 31, 2011 at 5:51 AM
    FLtaco06
    FLtaco06 Scalp Em
    Florida
    06 Prerunner
    What is the best kind of clear coat to use with the duplicolor rattle can?
  14. Jul 31, 2011 at 5:58 AM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    I found this process the absolute hardest when doing my Satoshi. I gave up and eventually bought spary on Bed liner. It worked like a charm and is holiding up really well. It's not colored matched but I love the look
  15. Jul 31, 2011 at 6:02 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    I would skip sanding that whole thing and just buy a new partsgeek grill for 30 bucks and save a lot of time and headache and just start fresh.
  16. Jul 31, 2011 at 6:18 AM
    Priddle
    They don't ship outside the US. I am in Canada. Good try though.
    This morning it was 100% dry and the paint seemed solid. Oh well, c'est la vie.
    I found some Dupli-color Adhesion Promotor this morning. I'm going to sand the hell out of it and give it 3-4 coats of that, and then color within 10 minutes of the last coat as it says on the can.
    The can also says I can apply it over old paint as long as its clean. So I'm not going to be overly concerned if I don't get all the previous paint off.
  17. Jul 31, 2011 at 6:20 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    gotcha. I would just sand smooth the rough spots and paint over everything else.
  18. Jul 31, 2011 at 6:30 AM
    neoflex
    neoflex Well-Known Member
    For color matching I usually just cheat and visit a body shop for small parts like a grill. More often than not it will only run you a couple hundred bucks and the results are usually far superior to that of a rattle can not to mention will last longer. If I'm just going to convert something to black I will rattle can but color matched body parts always look better if done by a good body shop. Plus those Duplicolors always seem to be close but rarely ever spot on in my experiences.
  19. Jul 31, 2011 at 6:48 AM
    Priddle
    Thats a good point as the color didn't seem to quite match up. I thought it just needed to dry properly and maybe the clear coat would bring the colour out but it looked more silver than beige.
  20. Jul 31, 2011 at 7:03 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    I would agree here - Especially since the OP has a nice new truck and the grill being a focal point as it is.
