Painting calipers and skid plate
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LonghornTaco, Oct 28, 2008.
  1. Oct 28, 2008 at 10:50 AM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I saw some posts about painting your calipers, but I'm still a little short on exactly what kind of prep work is needed before painting. Can someone enlighten me?
    Also, is it difficult to remove the calipers for painting? I have changed brake pads before on a car I had, but it's been a LOT of years... What about the rear drums?
    Thanks!
  2. Oct 28, 2008 at 10:55 AM
    808trdsport
    808trdsport Well-Known Member
    Honolulu
    08 Tacoma TRD Sport Prerunner
    6000k HIDS, double tint in the back and tint front side windows, CGS cat back exhaust, AFE Pro Dry filter
  3. Oct 28, 2008 at 11:04 AM
    Brunes
    Brunes abides.
    Rotorhead
    That's a pretty good how to. I'll add a few things from my experience the oher day
    I wasn't worried about painting the back of the calipers...so I masked the rotor REALLY well and painted it without removing the bolts.
    I used a filler primer first coat because the calipers are rough and I wanted a bit of a smoother look. You don't have to prime them if you don't want to.
    Follow the directions on the can or box of paint you use- It will affect the finish.
    Make sure to use the right product too...It matters.
  4. Oct 28, 2008 at 11:07 AM
    808trdsport
    Honolulu
    yup i agree. Just use some brake clean stuff with a small toothbrush first. Then mask it up good. DO NOT GET ANY PAINT ON THE BRAKES! That would be very bad. Then go slow using a small hobby brush. Most brake assembly's just has one bolt and it can swing away. I haven't yet worked on my taco's brakes so I'm not sure if its the same.
  5. Oct 28, 2008 at 11:15 AM
    LonghornTaco
    Minnesota
    Oh - you actually "brush" on the paint? It's not spray paint?
  6. Oct 28, 2008 at 11:17 AM
    808trdsport
    Honolulu
    i used the one you buy from wal mart. its a kit with everything inside. and yes i would brush it on. much cleaner.
  7. Oct 28, 2008 at 11:34 AM
    Brunes
    Brunes abides.
    Rotorhead
    You can get spray paint...They make it. I used it.
    Spend the time prepping and you won't have any issues. Make sure you spray when the wind is calm.
    The pictures of the prep work I did weren't saved...But I used a whole newspaper and wrapped EVERYTHING
  8. Oct 28, 2008 at 12:47 PM
    808trdsport
    Honolulu
    [​IMG]Customizing brake calipers is a whole lot easier. You can brush on color with Dupli-Color® High Performance Caliper Paint Kit. The complete kit includes everything you need to add color and style to your brake calipers. Available in 4 colors. Caliper Paint Kit goes on with a brush, so there’s no need to remove the calipers before painting. Just mask with tape and brush on color. Everything you need is included; Caliper Cleaner, stir stick, paint brush, masking tape and complete instruction book. The Caliper Paint features Ceramic Resins for maximum heat dissipation. It won’t blister, flake, crack or peel. Dupli-Color's High Performance Caliper Paint with Ceramic Kit withstands temperatures up to 500 degrees, is brake dust resistant, fast drying, and provides a durable finish.
    KIT INCLUDES:
    • Dupli-Color Caliper Cleaner to remove grease and dirt
      from the caliper to ensure best painting surfaces
    • Dupli-Color Caliper Paint is designed to withstand high
      temperatures
    • Application brush and stir stick for easy application
    • Masking Tape Roll (3/4" x 20ft)
    This is the kit I bought from Wal-Mart.
  9. Oct 28, 2008 at 1:20 PM
    Brunes
    Brunes abides.
    Rotorhead
    Didn't pick up on it the last time- The rear drums are the same way. Prep and mask off well and you'll be fine.
  10. Oct 28, 2008 at 5:15 PM
    LonghornTaco
    Minnesota
    What about painting the skid plate? Would Duplicolor spray paint be good for that too? What about sanding/primer? Necessary?
  11. Oct 28, 2008 at 6:16 PM
    Brunes
    Brunes abides.
    Rotorhead
    How hard do you plan on running around?? You might want something a lil more bullet proof (like rhinoliner) if you will be wheeling alot. If you are just driving around regular like...paint should work fine.
    Depending on color you can use different types-Duplicolor makes a "wheel and rim" paint or the "caliper" paint is suspossed to be a bit more wear resistant.
    Sand it down with 800 or so...Wipe it down down with alcohol or another non greasy cleaner. Prime and Paint. Bolting it off the truck is prolly the best idea. Give it the right time to cure before bolting it back on. Consider using some sort of clear coat or something if you want it to stay "nice"
  12. Oct 28, 2008 at 9:42 PM
    LonghornTaco
    Minnesota
    Not hard at all - some, but not a whole lot. One day I'll invest in some Bud Built under armor, but for now, it's just for looks.
    I went to O'Reilly's tonight and bought some Duplicolor spray paint and primer, and I found the Duplicolor Caliper kit that 808TrdSport talked about.
  13. Oct 29, 2008 at 5:29 AM
    Brunes
    Brunes abides.
    Rotorhead
    Nice Nice...Good luck man...Can't wait to see it.
