Painting doors
Discussion in 'General Automotive' started by rab89, Dec 7, 2009.
  1. Dec 7, 2009 at 4:32 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    I need to paint a couple doors on a friends nissan pathfinder, from silver to white, i have an air compressor, so I can get a sandblasting kit, and paint gun set up. is it hard to do? any tips or advice? the body shop wants a lot to do the work, so we'd rather do it ourselves
  2. Dec 7, 2009 at 4:39 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Unless you are dealing with rust, do not use the sandblaster. Sanding down the paint to rough it up is quite sufficient. I hear that the Duplicolor Paint Shop stuff is easy to spray. I would recommend practicing on something first. Keep as much dust away as possible.
    If you are looking for a really good looking job and this is your first time, you might be disappointed.
  3. Dec 7, 2009 at 11:51 PM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    ok so no sandblaster, it doesn't have to be perfect, but descent for a DD.
    I was thinking we'd use the garage and section off an area with some tarp, including the floor, to keep the dust out.
    would you recommend one of those paint can handles?
    like this
    or should we get a set up to use the air compressor?
  4. Dec 7, 2009 at 11:55 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    its gonna look real blotchy if you use rattle cans. rattle cans are good for small areas but the paint doesnt cover well, its tough to get consistency and the paint is really thin (why it doesnt cover well) so its pretty easy to chip or scratch. If you want to go a good job dont get a cup gun get HVLP
  5. Dec 7, 2009 at 11:59 PM
    Yoytoda
    Roland
    completely stock
