Painting factory fender flares
Discussion in '1st Gen. Tacomas (1995-2004)' started by hardtaco, Dec 11, 2008.
  1. Dec 11, 2008 at 2:19 PM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Has anyone had any luck painting the factory black plastic fender flares on their trucks? Mine have faded and I am tired of putting different kinds of plastic "dressing" on them to keep them shining. It doesn't last long and when it rains it makes a mess. Is there a really good durable paint to use for this type of plastic? I wouldn't mind doing the front lower plastic facia either if the flares come out good. The sun just beats that plastic up and turns it gray looking.
  2. Dec 11, 2008 at 2:31 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    '13 MGM AC 4x4 TRD OR
    Husky front mud flaps, OEM bed mat, 3D floor mats, Wet Okole seat covers, fog lights anytime mod, rear diff breather extension, aluminum Relentless tailgate reinforcement, NWexpo corner gussets, 265/75-16 Hankook Dynapro ATM
    I did exactly what you are describing on a Jeep TJ that I had before. At a paint specialty store, I found what was called 'bumper paint', it was black and had a bit of a texture to it. After cleaning off the flares, I used a plastic primer, which seems to make the plastic a little more soft at first, but it's supposed to make the paint adhere better. It worked very well to keep the fenders black for quite a while, much longer than the 'back to black' type of product which don't work well for very long at all.
    I have to say, though, the bumper paint idea, although it lasts a long time, years, in fact, it does eventually turn gray in spots from the sun also. I saw the TJ the other day and the flares have grayed again...if you're interested in what I used, I may still have the paint at home, I can get a brand and maybe product number.
  3. Dec 11, 2008 at 2:44 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    A brand name would be great, thanks. I would be very satisfied if it lasted a couple of years.
  4. Dec 11, 2008 at 4:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can clean and prep the flares really well, then use an adhesion promoter spray for plastics on them before you paint. it helps the plastic "hold" the paint really well. when it gets warmer.............im gonna prep mine and use some herculiner bedliner on them.
  5. Dec 11, 2008 at 8:23 PM
    glwood6
    Gary
    Albuquerque, NM
    I found the paint. The brand is SEM.
    The part numbers are 38363, Sand Free, which says 'promotes adhesion on plastics', and 39103, 'flexible bumper coater', 'renews bumper appearance'.
    I did my TJ flares about 4 years ago, and just noticed the graying coming back...not too bad...if the flares on my Tacoma ever start to fade, I would probably do the same to them.
  6. Dec 12, 2008 at 2:54 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    Perfect! Thanks for the info. I feel a project coming on within the next couple of weeks.
  7. Dec 12, 2008 at 3:18 AM
    FoxySandChick
    FoxySandChick Well-Known Member
    Kristin
    Henderson, NV
    07 DC 4x4 Base model V6 Impulse Red Pearl
    De-badged, limo tint, black wet okole's, weathertechs, extra d-rings, TSB bilsteins
    Some people have used bed liner material, like the herculiner stuff to do the fenders and bumpers.
    Check out Taconinja's gallery, he has pics of his and it looks good.
  8. Dec 12, 2008 at 4:26 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
  9. Dec 12, 2008 at 12:48 PM
    glwood6
    Gary
    Albuquerque, NM
  10. Dec 12, 2008 at 2:34 PM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
