Painting fender flares
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hogfan1, Nov 5, 2015.
  1. Nov 5, 2015 at 8:07 AM
    Hogfan1
    Hogfan1 [OP] Active Member
    I've done a bit of searching and can't find what I'm looking for. I want to paint my stock silver fender flares black. Two of them were in really rough shape. I don't want to pay to have them color matched yet so I think I've decided to just paint them black myself.
    Is it necessary to sand it prior to painting them? If so, with what? These things aren't exactly the easiest things to sand paint off. What type of paint would you recommend? I've seen some guys line x and use the black trim paint. Thanks.
  2. Nov 5, 2015 at 7:43 PM
    Hogfan1
    Man, I figured there would be more info out on this.??
  3. Nov 5, 2015 at 7:45 PM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Is the paint bad on them now? I'd not you just need to scuff then up and not take the paint off. ..
  4. Nov 5, 2015 at 7:46 PM
    Hogfan1
    It is on three of them. One is in pretty decent shape.
  5. Nov 5, 2015 at 8:57 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Take some low grit sandpaper and get the rough spots smooth, work your way up in grit until it's smooth enough that the scratches will get filled in.
    Of course first remove the flares, that involves removing a few 10mm bolts and then ripping them off. You will break 95% of the clips, there isn't really an easy way around this. You can buy new clips on eBay for less than $5.
  6. Nov 5, 2015 at 9:18 PM
    Hogfan1
    I got the flares off and somehow managed to only break a few. So it's ok to hit it with pretty rough sand paper to get factory paint off? Then sand it with a finer paper once most paint is off?
  7. Nov 5, 2015 at 9:28 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah. You don't have to get ALL the paint off, it just needs to be smoothed down. Wouldn't hurt to lay some primer down, lightly sand and then put on your black paint after, unless you use a 2 in 1.
  8. Nov 5, 2015 at 9:35 PM
    Hogfan1
    Ok thanks. Looks like I'll have a little project this week.
