Painting Grill
Discussion in 'Street Trucks' started by jtt, Mar 24, 2011.
  1. Mar 24, 2011 at 12:46 AM
    jtt
    jtt [OP] Member
    Justin
    Los Angeles
    4x4 double cab
    I was wondering if anyone had advice on how to paint the grill matte black. Any help would be greatly appreciated!
  2. Mar 24, 2011 at 2:01 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Welcome, I see this is your first post. There are several ways you can go about doing this,. some folks simply paint it, others chose to use a vinyl wrap. If you seach matte black grill you should see several post on this topic.
  3. Mar 27, 2011 at 11:46 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    PLASTI DIP!!!!!!!!
  4. Mar 27, 2011 at 11:47 PM
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    2015 trd offroad
    i knew this was coming
  5. Mar 27, 2011 at 11:50 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    1997 White AC 5-Lug
    i did mine today, i taped it off and everything carefully and still messed it up. if you look up close you can see the tape peeled up the plasti dip. but from far away it looks fine. and also if you work on your engine a lot seems like from all the rubbing it would come off pretty easy. but it hasnt been on more then 12 hours
  6. Mar 28, 2011 at 11:04 AM
    pinktaco808
    pinktaco808 Hot Steppa
  7. Mar 28, 2011 at 4:22 PM
    07TacoRidah
  8. Mar 30, 2011 at 2:38 PM
    Sixfeathers
    Sixfeathers Well-Known Member
    Kreg
    Maryland
    2011 Access Cab
    Led lights: Replaced Bulbs in front,Fog Light modification, Westin Nerf Bars, TS mod,
    I have a 2011 I would like to paint to match my truck.Any ideas on how to have the chrome paintable?
  9. Apr 8, 2011 at 10:51 PM
    MMazz365
    MMazz365 Well-Known Member
    Michael
    NY
    TRD Off Road
    -flowmaster dual side exit exhaust -3 inch lift -cb radio -scanner -DTRL's -Fogs Anytime -Truxedo Soft Tonnahu Cover -eyelids -grillcraft upper and lower -fogs behind the grill
