painting grill
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikeyramone, Aug 24, 2009.
  1. Aug 24, 2009 at 10:03 AM
    mikeyramone
    mikeyramone [OP] 220 - 221 Whatever it takes
    Westfield,Ma
    2005 4X4 TRD Sport Speedway Blue
    Sylvania Silverstar headlights, vent visors, Advantage Tri-fold tonneau cover, pop n lock, Sirius radio, auto dimming mirror, AFE Pro-Dry air filter, secondary air filter removed, Magnaflow muffler, Hood scoop decals, Painted grill, Devil Horns!!!
    Has anyone tried to paint the 2 black horizontal inserts that are in the grill? I've been to 2 diff body shops and one said that the paint wouldn't stick the other said it could be done without a problem. Any help is appreciated. Thanks
  2. Aug 24, 2009 at 10:12 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yes you can do it. Use radiator paint so as not to affect the heat properties of the radiator.
  3. Aug 24, 2009 at 10:13 AM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i used rustoleum from home depot to paint mine
  4. Oct 13, 2009 at 6:25 PM
    pikegi
    pikegi Well-Known Member
    Brandon
    South Carolina
    09 WHT LB DC TRD Sport 4X4
    Any pics
  5. Jan 5, 2010 at 6:18 PM
    mikeyramone
    Westfield,Ma
    Here are pics after getting the grill painted, adding devil horns, eyelids and a TRD Sport decal to the hood scoop.:headbang::headbang:
  6. Jan 5, 2010 at 7:08 PM
    Buzzoff
    Buzzoff Don't go ninja'in nobody don't need ninja'in
    The Nickel/5th Ward
    09 Tacoma DC TRD Speedway Blue
    Blacked out windows, 5100's@1.75", KMC XD Hoss795 16x8
    ohhhhhh I like!!!
  7. Jan 16, 2010 at 2:13 PM
    lilgerber
    lilgerber Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    did you paint the surrounding of the grill also? that came out good, i plan on painting my chrome.
  8. Jan 19, 2010 at 9:02 AM
    mikeyramone
    Westfield,Ma
    The whole thing is painted except the "triangle" cut-outs next to the headlights. Those weren't painted because it's basically impossible to prep them for painting.
  9. Jan 19, 2010 at 9:06 AM
    ThreeMan
    ThreeMan Opinions Vary...
    Oswego, NY
    08 4x4 V6 TRD DCLB
    Eibach Springs with Billstien 5100's - Full Katzkin Leather - Back Flip Roll-X bed cover - Custom Projector/Dual Halo Headlights by ambiguous - Eagle Eye LED tail lights - LED Light Bar Mounted in Bumper - Wade In-channel Vent Visors - K&N Filter - 20% on the fronts - Rear AAL TSB - 4 Tie Down Mod - Pop N Lock - Running Boards - Billet Grille - Weathertech Mats - LED Map and Dome Lights - Optima Yellow Top - Redline Elite Hood Struts - Tunes: Eclipse 7100 HU - Eclipse IPC-106 Interface - Audison LRX 5.1K - Hertz Mille MLK2 Components - JL 13TW5 - JL cables and wires - Fully Deadened with SDS products - Metra dash kit - Custom Sub Box and Amp Rack - Still Under Construction.
    I like it, good work. Did you do it, or did the shop?
  10. Jan 19, 2010 at 10:27 AM
    mikeyramone
    Westfield,Ma
    I had a body shop paint the grill and the eye lids at the same time so the color would match.
