Painting grille surround
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pugga, Aug 9, 2010.
  1. Aug 9, 2010 at 10:07 AM
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    I bought paint online from paintscratch.com, someone here recommended them, with the intention of color matching the grill surround and painting eyelids. I started with the Toyota emblem in the grille for a test piece so I didn't ruin my grille. I roughed it up with 600 grit, used their flexible primer, gave it a wet sand, then multiple coats of color and finally clear. The end result, it's close, but you can notice the color difference. Anyone have experience with their paints? They color match the paint to your color code and use dulicolor clear coat. Any one else use their paints and how did it turn out? Color is super white if it makes a difference. Thanks!
  2. Aug 9, 2010 at 10:35 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2002 Sliver-ade-o 2008 P71
    Yes
    how long did you let it dry? Paint will change color as it dries. The clear coat could also be the issue.
  3. Aug 9, 2010 at 10:37 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I painted my eye lids with some color-matched spray cans I got off of ebay. It is not exactly the same but you cant tell the difference unless you stare at it from 6 inches away. I dont think your ever going to get the exact match to be honest.:eek:
  4. Aug 9, 2010 at 10:50 AM
    Pugga
    Massachusetts
    I let it dry 2 hours between paint and clear. 20 minutes between coats. I followed the instructions when applying the color. Light coats at first, then build up to the wet coat. I set it up to dry overnight. If the clear is the issue, any ideas?
  5. Aug 9, 2010 at 10:51 AM
    Pugga
    Massachusetts
    I guess if I just leave the truck dirty I'll never know the difference! :D Unfortunately, my truck doesn't see a whole lot of mud and I'm on the anal side when it comes to things matching. One way or another, I'll get it right!
  6. Aug 9, 2010 at 10:53 AM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah I understand what your saying but its one of those things where it will bug you for a couple weeks, then you wont even notice it anymore.:cool:
  7. Aug 9, 2010 at 10:58 AM
    TacoDanny
    TacoDanny Well-Known Member
    OC, CA
    '10 4x4 Offroad
    King CO w/ res, Camburg UCAs, King Rears w/ res, Ironman Rear Leafs, CBI Rear Bumper w/ Swingout, KR Fab sliders, Ultragauge, Satoshi grill, Weathertech floor mats, DeMello 3 Hoop Front Bumper, AFE CAI Intake, Retrofitsource FX-R Projectors
    I gave up on colormatch for now and just did mine all flat black this weekend. We'll see how I like it for the time being.
  8. Aug 9, 2010 at 10:59 AM
    militaco
    militaco Well-Known Member
    Hawaii
    2009 Double Cab, '99 Regular Cab
    I used the duplicolor for my eyelids (Super White) and the match was pretty close, but when i applied the clear, thats what threw the coloring off, but after a while you get used to it.
  9. Aug 9, 2010 at 11:08 AM
    Pugga
    Massachusetts
    I'm supposed to be doing the BHLM and putting on white eye lids. But, if the paint doesn't match, I may switch gears and do a white head light mod and scratch the eye-lids. Ahhh, decisions....
    In the end, you guys might be right, it'll bug me for a week then I'll forget all about it. I'll just pull into my parking spot so I don't have to see the front of the truck for a while.
  10. Aug 9, 2010 at 11:10 AM
    Pugga
    Massachusetts
    Can't bring myself to go blacked out. Everything on my truck is color matched or stainless steel. I'm too far gone to start blacking things out now!
  11. Aug 9, 2010 at 12:01 PM
    LUSETACO
    Dennis
    South Central Pee A
    Yes
    That's what I'm getting at. "clear" usually has a slight yellow tint, so it's really going to discolor something that's painted white.
  12. Aug 9, 2010 at 12:08 PM
    Pugga
    Massachusetts
    I'm going to try some rubbing compound and maybe a wet sand tonight. I'll let you know what the results are!
    Thanks for your help and input everyone
  13. Aug 9, 2010 at 12:10 PM
    ChompsterTacoma
    ChompsterTacoma Well-Known Member
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    Even the touch up paint I got from Toyota parts is not a perfect color match(superwhite) Slightly darker. I even went back to parts and asked again. So I went to a local body shop to have then whip me up a bottle of touch up. (perfect I might add) Some shops do this. You can check local paint stores who do paint match and check to see if the color is the same as the one you ordered from online.
  14. Aug 9, 2010 at 12:25 PM
    Pugga
    Massachusetts
    Would they make a spray can or just the small bottle of touch-up? The only reason I went to this online store was for the spray can.
  15. Aug 10, 2010 at 12:06 AM
    ChompsterTacoma
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    Find a local paint shop and call. They do spray cans too. Look it up and ask. Ask body shops too. They sometimes ask for your gas lid to keep to make sure the color really match. Hope that help!
  16. Aug 10, 2010 at 5:37 AM
    Pugga
    Massachusetts
    I found the solution! I picked up some Meguire's polishing compound last night and went over the newly painted part a couple times. It's still not perfect but it's a lot closer! It took a lot of the yellow out, hopefully I didn't just strip the clear coat...
  17. Aug 10, 2010 at 7:05 AM
    Simon's Mom
    Judy or Jude :)
    SBurl Vermont
    13 TRD OR DC MGM
    Stock for now
    I didn't do the rattle can but when the dealer color matched my grill they paint chipped it against the truck. Honestly, I think once it is on there you will not even notice and almost everyone else won't notice too. Cool to do your own! :)
  18. Aug 10, 2010 at 8:28 AM
    Pugga
    Massachusetts
    I'll have some time over Labor Day and figured it'd be a neat project. I'm doing the BHLM and color matching eye lids also so I figured while I was painting... With the polishing compound it actually brightened up a lot and make the ratle can a lot closer to the truck color. I'll have to post up some pictures when it's done and let you guys be the judge.
  19. Aug 10, 2010 at 8:34 AM
    Bobo_1
    Bobo_1 Well-Known Member
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    Hopefully the paint has instructions for waiting how long between coats. Usually, it is just flash time which is about 10-20 minutes. You go past that then adhesion is not as good.
  20. Aug 10, 2010 at 8:36 AM
    Bobo_1
    Bobo
    Maryville, TN
    09 TRD Sport L-Bed
    The course is usually, prep, paint, clear, color sand, polish.
