Painting hood Tacoma 2004
Discussion in '1st Gen. Tacomas (1995-2004)' started by poppahank, Sep 18, 2019.
  1. Sep 18, 2019 at 10:58 AM
    poppahank
    poppahank [OP] Member
    henry
    2004 tacoma prerunner
    I would like to paint the hood and top of my 2004 Tacoma, doing this for protection more than looks. I was thinking of using Dupli-color (black) and their primer. Do I need to clear coat it also. As mentioned, this is for protection ( my be getting to rust point) not really for looks.
  2. Sep 18, 2019 at 11:41 AM
    firstgentacotuesday
    firstgentacotuesday Well-Known Member
    CA
    Superrwhite ‘01 3.4 4x4
    Stock(:
    Not a professional by any means but ya i’d clear coat it especially if your main goal is rust protection. Leaving it w/o a clear coat would be pointless to be honest.
  3. Sep 18, 2019 at 11:42 AM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    I’d clear it with spray max clear
  4. Sep 18, 2019 at 11:43 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    hood is easy take it off strip it and spray it, roof on the other hand... a little more finesse but still not that difficult, and yeah clear it or its gonna fade, rust, and just look bad.
  5. Sep 18, 2019 at 11:46 AM
    jbrandt
    jbrandt ......LOADING
    Justin
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    Clear coat is a protectant, so yeah, I would.
    You going to rattle can it?
    Just remember that 90% of a good looking (and functioning) paint job is the prep work. Sand it down to remove the old clear coat and at least the top layer of paint.
    I've also seen some people use like a bedliner material on their hoods (or their whole truck for that matter).
  6. Sep 18, 2019 at 12:00 PM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4
    33's Bedliner Nerf Bars (Custom)
  7. Sep 18, 2019 at 12:16 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    On the roof there is a rust prone area. Typically where the windshield meets the roof line there. If you can - remove the windshield so you can get all that sorted out. Probably a little rust under there. If you don't and you go and paint all that the rust will just keep moving. Damn shiz likes to eat Tacomas for lunch.
  8. Sep 18, 2019 at 12:30 PM
    Fatal_Paradox
    Bardstown, KY
    2003 Tacoma DC 4x4
    @Xbeaus being near the rust belt. I will now have nightmares of what is lurking behind my windshield seal of my truck.
  9. Sep 18, 2019 at 5:11 PM
    jenk
    jenk Well-Known Member
    Jen
    Central Coast of CA
    2001 Black Tacoma TRD Prerunner
    I highly recommend vinyl wrapping it, less mess and a lot easier to pull of unless you're a professional painter, plus awesome protection.
  10. Sep 18, 2019 at 5:41 PM
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    This is soon on my list of things to do. Want to get ahead of the rust since my Jade Green Clear coat just went caput on both hood and roof.
  11. Sep 19, 2019 at 6:19 AM
    Fatal_Paradox
    Bardstown, KY
    2003 Tacoma DC 4x4
    My clear coat is starting to bubble on my hood. I'm thinking of wet sanding the rough spots of the clear coat and re - spray before it gets any worse.
