Painting In Cold Weather
Discussion in 'Off-Topic Discussion' started by jeremy_283, Nov 28, 2011.
  1. Nov 28, 2011 at 9:36 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    What can happen? Like I got paint that's rated down to 35F and it was borderline yesterday. But it stayed above 35F for about 6 hours. But it got below freezing that night. It's that Valspar Duramax paint.
  2. Nov 28, 2011 at 9:37 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Worst case, it peels and you have to scrape it off and do it again.
  3. Nov 28, 2011 at 9:46 AM
    jeremy_283
    How long till I would see it start peeling you think?
  4. Nov 28, 2011 at 9:51 AM
    Pugga
    Massachusetts
    Depends, if it was really an issue, it wouldn't hold and you'd be able to tell the next day. If it held on and looks good a few days later, I wouldn't worry about it unless something does happen. It may have done something detrimental to long term durability but I can't speak to that, I just know first hand what happens when painting in less than ideal conditions. If you were within the specified conditions when you painted and it stayed that way for 6 hours, I'd say you're probably fine if you're not seeing signs of the paint not sticking yet. I've found humidity seems to be more of a factor than temperature. What did you paint, if it was the side of the house, the temp may have dropped but your house will radiate heat so the surface may not have gotten as cold as you think.
  5. Nov 28, 2011 at 3:25 PM
    jeremy_283
    Yea I painted my house. It was a latex based paint too.
  6. Nov 28, 2011 at 3:30 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    You should be okay. When they say that the paint is rated for 35F then there is usually a safety factor in there. I assume if you say it got below freezing you are talking low 30s, not subzero temperatures. My guess is that it had already cured by the time it reached those freezing temperatures, which was probably early morning rather than just after you finished painting.
    By the way, we are still enjoying mid 80s here in Florida.:p
