Painting my original rims. Any suggestions?
Discussion in '1st Gen. Tacomas (1995-2004)' started by tristen247, Feb 2, 2014.
  1. Feb 2, 2014 at 9:01 PM
    tristen247
    tristen247 [OP] Member
    tristen
    colorado
    97' Tacoma SR5 V6 4x4 Manual 5-spd
    Cold air intake system and turbo charger
    I have quite a bit of water spots and other junk on my rims and it doesn't seem to clean off. So my next option is to paint them. I was just wondering if my green tacoma would look better with the original silver or black. What are your opinions?
  2. Feb 2, 2014 at 9:06 PM
    frankakashane
    frankakashane Well-Known Member
    Frank
    San Diego, California
    06 White 4x4 TRD SR5 O/R Pack
    Icon extended travel shocks front~Icon resi extended travel rear shocks~Alcan rear springs~total chaos UCAs~Wheelers super bumps front and rear~Diff drop~steel brake lines~Alpine single din stereo~blacked out emblems~front 1.25" spidertrax wheel spacers~carrier bearing drop~TRD cat back exhaust
    you could always plasti dip to get a feel for it. If it grows on you, keep it. If it doesn't, just remove the plasti dip with some WD-40 and go a chrome/silver color.
  3. Feb 2, 2014 at 9:16 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Its all in the prep. Go black
  4. Feb 3, 2014 at 7:49 AM
    Tinmann
    Tinmann Well-Known Member
    NorCal
    If you don't want to do it yourself, here's a company that can do it for you. Perhaps you have one close by so you can get a quote. I don't think its as expensive as you might think.
    I haven't had them paint a wheel for me, but I did have them repair an aluminum wheel that had some serious curb rash on it and it looks as good as the OEM wheels I have on the car.
    Black would be my 1st choice though.
    http://www.kwicksilversac.com/services/powder-coating/
  5. Feb 3, 2014 at 9:35 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Have them blasted, then repaint with black PPG epoxy primer (gloss or satin) and then if you so desire, the PPG slow to medium velocity epoxy clearcoat (also available in gloss or satin).
  6. Feb 3, 2014 at 10:24 AM
    trailbikerider
    trailbikerider Well-Known Member
    Kalamazoo, MI
    I would have them powdercoated. The previous owner of my truck spray painted mine black and didn't prep them, so they are starting to chip and peel.
  7. Feb 3, 2014 at 10:29 AM
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
    I painted mine with Duplicolor Graphite. Looked great.
  8. Feb 3, 2014 at 10:32 AM
    Germ
    Germ Master Navigator/Zipper Operator
    Arizona
    2013 TRD OR DCSB
    Any body got any suqquestions or link for prep/products to diy?
  9. Feb 4, 2014 at 8:41 PM
    tristen247
    tristen
    colorado
    I'll give the plasti dip a try, if it doesn't work out then I'll sand blast them
  10. Feb 4, 2014 at 8:49 PM
    Germ
    Arizona
    2013 TRD OR DCSB
    Just a heads up the derp holds dirt like crazy.
  11. Feb 4, 2014 at 9:14 PM
    frankakashane
    Frank
  12. Feb 5, 2014 at 10:42 AM
    tristen247
    tristen
    colorado
  13. Feb 5, 2014 at 10:58 AM
    Germ
    Arizona
    2013 TRD OR DCSB
