Painting My Rims
Discussion in '1st Gen. Tacomas (1995-2004)' started by foxmx258, Jun 5, 2010.
  1. Jun 5, 2010 at 9:07 PM
    foxmx258
    foxmx258 [OP] Active Member
    Jacob
    Spartanburg SC
    04 4 cylinder preRunner
    Can you tell me everything i have to have to do this and the steps of doing it? and if i screw up is there a way i can get rid of it?
  2. Jun 5, 2010 at 9:11 PM
    747 function > form
    1st Gen.
    Get rid of it: Have it media blasted.
    From what I've read (here): (i) Clean/sand your wheels; (ii) 2-3 coats of self-etching primer; (iii) 2-3 coats of color; (iv) 2-3 coats of clear.
    Good luck...post pics when you're done.
  3. Jun 5, 2010 at 9:12 PM
    foxmx258
    Jacob
    Spartanburg SC
    What kind of sand paper should i use? And it seams like the paint will chip off easily will it?
  4. Jun 5, 2010 at 9:28 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    This, minus the clear if you plan on scratching them up eventually. That way you can touch them up easily.
  5. Jun 5, 2010 at 10:19 PM
    foxmx258
    Jacob
    Spartanburg SC
    so clean the rims spray 3 coats of black primer let it dry then spray 2 coats of black paint then let it dry??? what kinda of paint should i use???? I NEED HELP BAD!! haha
  6. Jun 5, 2010 at 10:21 PM
    foxmx258
    Jacob
    Spartanburg SC
    oh yeah how do i no if i had sanded them too much or too little and what kind of sand paper should i use?
  7. Jun 5, 2010 at 10:38 PM
    foxmx258
    Jacob
    Spartanburg SC
    Hey Steve o 77, on your second picture what did you do to get your rims to look like that...i want mine exactly like that except i want the middle black too can you please help me thanks
  8. Jun 6, 2010 at 6:47 AM
    tacomabud
    tacomabud Well-Known Member
    Bud
    RI
    04 Black Xtra Cab
    K&N replacement, 4" Deck plate mod, Thrush Welded muffler, 2nd Gen. TRD rims, Herculinered bed, Grey wire mod, OME lift w/ 883 coils and AAL, 265/75/16 BFG A/T, AP 1.5" wheel spacers
    I just painted my wheels last week... I used sand paper and steel wool to scratch up the clear coat on the rims. After, I washed the rims, let them dry, and then wiped them with Acetone to get rid of any existing grease or dirt. I had to paint my wheels with the tires still on the rim, so I taped off my tires to make sure I did not get any over spray on the tires. After taping them off, I sprayed the rims with 2 coats of Rustoleum Performance Wheel Paint. Picked it up from Autozone for ~$8
  9. Jun 6, 2010 at 8:43 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    I did this. Only I used krylon gloss black paint and rustoleum self etching primer from autozone. I also removed the wheels from the truck so I could lay them down for painting.
  10. Jun 6, 2010 at 8:57 AM
    kbx10
    kbx10 Well-Known Member
    Kyle
    Chicago
    The beginning of something big...
    Tint, Autopage Security
