painting peeling rims
Discussion in 'Wheels & Tires' started by nhgranite, Apr 11, 2011.
  1. Apr 11, 2011 at 4:40 PM
    nhgranite
    nhgranite [OP] Well-Known Member
    N.H
    fisher plow
    my 06 trd rims are f'd. i'm doing the ol' black paint job on them. i will have to remove the paint bubbling areas which will leave and uneven surface. should i try and remove all the factory paint or spray an ass load of paint on them? i want them to look even. if i need to remove it all whats the best way? i can't de-tire them and have them blasted unfortunately.
  2. Apr 11, 2011 at 6:49 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    The only way you're going to get a good result is stripping the old paint. If you can't blast them, you will have to sand the crap out of them. I'd start by pulling the weights (mark the spots!) with 60 until it's all off, then maybe smooth them out with 240. No use in going higher, wheel paint is thick. Few coats of primer, then a few coats of paint. Follow the directions on the can, you should get a good result.
  3. Apr 11, 2011 at 6:52 PM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Yes definitely sand the crap out of your wheels. You need to get to the bare metal. You will thank yourself every day in years to come. Make sure you prime them, and maybe right before priming rub the wheels off with acetone.
  4. Apr 11, 2011 at 6:54 PM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    im currently plasti dipping my rims..too bad i can only do 1 rim at a time
  5. Apr 12, 2011 at 3:29 PM
    nhgranite
    N.H
    fisher plow
    i figured i'd have to go bare metal. not fun. i wonder if i could wire wheel them with my die grinder.
  6. Apr 12, 2011 at 4:16 PM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    Are you just going to rattle can them? If so, they wont last very long. Prep is the key, but be prepared to constantly touch up your wheels if you dont powdercoat them.
  7. Jun 22, 2011 at 11:09 PM
    crashbandicoot
    crashbandicoot Member
    Edwin
    Cali-Funk
    02 PreRunner
    do you have a picture of your plasti dipped rims? do they look good? i feel like it would come off constantly
