painting radiator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bluebeast, Mar 30, 2010.
  1. Mar 31, 2010 at 11:06 AM
    #41
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    I've never heard of any ill effects from painting the radiator.
  2. Mar 31, 2010 at 11:25 AM
    #42
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    "Heat transfer is the transition of thermal energy from a hotter mass to a cooler mass. When an object is at a different temperature than its surroundings or another object, transfer of thermal energy, also known as heat flow, or heat exchange, occurs in such a way that the body and the surroundings reach thermal equilibrium; this means that they are at the same temperature. Heat transfer always occurs from a higher-temperature object to a cooler-temperature one as described by the second law of thermodynamics or the Clausius statement. Where there is a temperature difference between objects in proximity, heat transfer between them can never be stopped; it can only be slowed.
    Thermal insulators are materials specifically designed to reduce the flow of heat by limiting conduction, convection, or both. Radiant barriers are materials which reflect radiation and therefore reduce the flow of heat from radiation sources. Good insulators are not necessarily good radiant barriers, and vice versa. Metal, for instance, is an excellent reflector and poor insulator."
    i guess the only way to truly test this is to test the temp of one painted and one not painted....i think the bottom line is it will not effect it enough to notice. Plenty of people here have done it and have not had there trucks overheat.
  3. Mar 31, 2010 at 11:36 AM
    #43
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    DON't use bedliner ! [​IMG]
  4. Mar 31, 2010 at 11:49 AM
    #44
    csuviper
    csuviper Moderator Moderator
    Brian
    Broomfield, CO
    2012 Tundra Rock Warrior 5.7L 4x4
    3" Toytec Ultimate Lift, 315/70R17 Duratracs, RW Wheels, Grillcraft Grill, Toyota "Raptor" Lettering and more
    The heat transfer is done through convection in two ways. The warm fluid transfers heat to the metal and the metal to the air. To calculate the rate of heat transfer you will only need the surface area, temperature difference and the convective heat transfer coefficient. The coefficient in this case is the air. The temp difference would be between the fluid temp and the air. This will give you a fairly accurate number. Now insulators do affect the coefficient but because the surface area is so large a couple coats of paint can be neglected. The rate of heat transfer from the fluid to the air should be within a few thousands of a BTU/hr. Story short: shouldn't matter.
  5. Mar 31, 2010 at 1:27 PM
    #45
    bakerla
    bakerla Man, Myth, Legend
    Lyndall
    Pearland, TX
    '10 4wd OR
    CBI Moab front and CBI Trailrider rear, Budbuilt skids, Shrockworks sliders, OME Dakars w/ OME Nitros, OME 886x w/ OME Nitros, Light Racing UCAs, stainless steel brakelines F/R, Cobra 75 w/ Firestik antenna, 255/85/16 Cooper ST Maxx on 1st gen alloys, Weathertech liners, Engo 9000S winch, stickars and other shit.
    Used my infrared thermometer after driving to work to measure the temperature. Not even above 100 degrees.
  6. Mar 31, 2010 at 2:14 PM
    #46
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    you mean the condensor?its in front of the radiator.shouldnt hurt it.
