Painting Rims black How?
Discussion in 'Wheels & Tires' started by socaltrucker00, Aug 31, 2009.
  1. Aug 31, 2009 at 12:23 AM
    socaltrucker00
    socaltrucker00 [OP] Well-Known Member
    Luis
    South California
    00' stepside tacoma
    rims
    i was wondering if there a thread or can anyone let me know what products and how to paint rims black?
  2. Aug 31, 2009 at 6:16 AM
    FL Forester
    FL Forester Well-Known Member
    Tallahassee, FL
    2014 MGM Double Cab
    2016 TRD Suspension upgrade, 1st gen TRD Wheels, 265/75/16 Cooper RTX
  3. Sep 1, 2009 at 7:26 PM
    zeski25
    zeski25 Well-Known Member
    FL561
    02SR5FullyLoaded4DR
    Westin Step Bar, 31 Terra Grapplers, Wrapped 15% Lumar
    riigg it to the maxx bro
  4. Sep 1, 2009 at 7:42 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    Use the search button on the top right. ;) There are many threads on this, may take a long time to read it all but should have everything you need.
  5. Sep 2, 2009 at 5:27 PM
    375taco
    375taco controlled pair?
    2010 TRD Sport 4x4 DC SB
    OME lift w/ 1" spacer. Built Right UCA's. Tinted all the way around. De-badged. Trimming up front
    Hey bro i was looking into the same thing with painting rims. Also painting them and touch ups. You should but done have to take the tires/rims off the truck. easier to prep, and the prep work is the most important. Take some steel wool or light sand paper. Just rough up the rims so paint will stick and the clean them off. crake cleaner or dawn dish soap. dawn will be the best because it removes all grease. Then primer you dont have to but you need to apply a lot of coats and let dry dor a while. just in a dry place. and re-apply a few times the more the better. and do some research for some tough paint. some will chip easy and some will act as a powdercoat. get some masking tape to tape off the tires and take your time. like i said the prep work is important. and grab a 6 pack and make a day of it maybe weekend job. they look great when they are done. send some before and after pics. if you clear coat you have to remember when they chip if they do and you touch up it will look off if you touch up and do not re-clear the rim. you should be fine with a few coats of black.
