Painting stock chrome grill. Suggestions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BigShow08, Jun 10, 2014.
  1. Jun 10, 2014 at 4:49 PM
    BigShow08
    BigShow08 [OP] New Member
    Austin, TX
    08 Pre Runner 4.0
    So I'm kinda tired of my chrome stock grill and have been wanting to color match it to the rest of the truck. Do I need to sand the chrome off or will a good scuff do the job? And can I get color matched paint at a parts store or do I need to go to a dealership?
    Thanks guys!
  2. Jun 10, 2014 at 4:54 PM
    Aw9d
    Aw9d That one guy
    scuff, primer, paint and go. Did this to my grill and bumper, holds up just fine.
  3. Jun 10, 2014 at 4:57 PM
    josh0351
    josh0351 Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    There's a color-match post on here somewhere. You'll have to search for it yourself though, my "search" super-powers are taxed for the day/week!
    Also, I painted my chrome grill with some Rust-Oleum flat black & several coats a few months ago and I noticed this weekend that it's already gouged down to the chrome where the hood rests against the top of the grill. So might be re-doing it here soon, with Plasti-Dip. My previous grill was dipped with NO issues - that stuff seriously holds up!
  4. Jun 10, 2014 at 6:59 PM
    karmatp
    karmatp Well-Known Member
    Trevor
    Chandler, AZ
    2016 4x4 4Runner
    old grill:
    New grill:
    Cost me about $180 out the door from my Toyota dealer. I was not a fan of the chrome around the grill either, but this was a simple, cheap fix.
  5. Jun 10, 2014 at 7:05 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
  6. Jun 10, 2014 at 9:18 PM
    TacoTom88
    TacoTom88 Gold Member
    Corey
    Northeast Georgia
    '17 DC TRD Sport
    I did this last year! It worked flawlessly except... DO NOT sand through the chrome. The chrome is difficult to get off but if you sand through it, it will peel like packing tape. If it does this you will be able to tell where it peeled off after you paint it.
    So, rough the chrome up with a fine grit sand paper then prime and paint!
  7. Jun 10, 2014 at 9:48 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I recommend getting some adhesion promotive from automotive touchup. Helps with having to paint plastic/chrome. Here's mine:
  8. Jun 11, 2014 at 7:30 AM
    AlanLoshbaugh
    AlanLoshbaugh Well-Known Member
    Alan
    Columbia, MO
    2013 Tacoma Double Cab 4x4
    Dupli-color may have a match for your factory color.
    Scuff with a mild 3M scotchbrite pad, primer, and paint.
    $180 for a factory replacement is a much nicer price than I would have guessed.
    As I wanted mine black, I plasti-dipped.
  9. Jun 11, 2014 at 8:39 AM
    ThomasMore66
    And 10 minute install.
