Painting truck with peeling clear coat?
Discussion in '1st Gen. Tacomas (1995-2004)' started by surfwax, Jul 27, 2017.
  1. Jul 27, 2017 at 11:26 PM
    surfwax
    surfwax [OP] Member
    I think I'm going to paint my truck. The clear coat in peeling all over the whole truck and it pisses me off. I have no real painting experience, but I'm just joining for it. I plan on buying one cheaper sprayer for paint and a nicer one for clear coat. Do I need to sand down to the filler or can I just sand the paint pretty good? Is primer necessary? My truck is green now painting it to white. Help
  2. Jul 28, 2017 at 6:17 AM
    austinsdad99
    austinsdad99 Well-Known Member
    1999 prerunner 3.4
    Ever since I got my 99 I've noticed a lot of 1st gens with peeling clear coats. And fading paint on hoods and roof of truck. Mine is peeling bad on the hood fender and top also. Wonder what the issue was with the paint on these
  3. Jul 28, 2017 at 6:19 AM
    Indy
    Indy Master of all I survey.
    You need to remove anything that's peeling you don't need to fo go metal. If you paint on top of peeling material the new will peel along with the old.
    Rmodel65 and cruxofthebisquit like this.
  4. Jul 28, 2017 at 7:21 AM
    kamaaina1
    kamaaina1 Well-Known Member
    Sean
    Vancouver, WA
    2004 TRD Tacoma x-cab
    A good paint job is only as good as the body prep work.....
  5. Jul 28, 2017 at 7:54 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    This. It's all in the prep work. Sanding, sanding, and more sanding.
    It's a lot of work man. I tried painting my truck toolbox according to how it would be done properly auto-body wise and it took me a week.
  6. Jul 28, 2017 at 7:57 AM
    Clearwater Bill
    Billy
    Largo Florida
    Nothing.
    They are old, have sat outside, and been generally unloved in terms of washing and waxing.
  7. Jul 28, 2017 at 8:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    Plenty of online reading to do on the topic.
    You need to be very patient. Done right, you can paint a vehicle with a roller and Rustoleum and have it look pretty good at 3-4 feet, maybe even 2 feet. Google $50 dollar paint job.
    If you are into off road, refinishing the truck with a premium bedliner is a consideration. www.monstaliner.com is a product that is available in a wide range of colors, doesn't have that annoying rough textured surface (no rubber particulate in it) and can be sprayed or rolled.
    However, even with that, prep is the key.
    You don't have to go to bare metal, but all the clear has to come off the panels that are peeling.
    Tech tip: You are going to need way more tools than 2 spray guns. And if you are still thinking paint basecoat/clearcoat, you need to call a price that stuff from a vendor. It ain't cheap.
    cruxofthebisquit likes this.
  8. Jul 28, 2017 at 8:15 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    If you're willing to do a LOT of sanding. You can make just about any paint job look good. Not a fan of liners unless it's just an offroad vehicle. i.e. deer lease. I'm in the same spot though, my clear has failed, not looking forward to the sanding.
  9. Jul 28, 2017 at 8:16 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    No real issue with the paint used,,just years of hot and cold cycles since 1999. Had some clear peel off this past winter for the first time due to the unusual amount of snow and cold we had,,but it is old weathered clear and was to be expected somewhat. Very surprised that it lasted this long. Keep the Turtle Wax applied and you get a few more before it happens. It doesn't last forever depending on where you live,,or it lived for a time. Tape off the peeled spots and go to work,,or strip and repaint and then clear the entire section if you want it to look even and not blotchy fixes.
  10. Jul 28, 2017 at 8:22 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    My 2002 is white and the paint/clear coat has held up fine even with heavy oxidation at times from lack of proper care (not any more though).
    IMO, it's the paint. Seems like any color (even on other makes) other than white is likely to have issues. Especially those forest green vehicles. Just the other day I snapped this pic of this blue 2nd gen
    Just look at that sad truck. I would be pissed.
  11. Jul 28, 2017 at 8:40 AM
    MagicMexican
    MagicMexican Well-Known Member
    Alejandro
    Pueblo, Colorado
    1998 Tacoma Xcab TRD 4WD 5-Spd
    Aftermarket Wheels
    I would keep the color the same, that way you don't have to worry a out door jam's and such. You could even just paint the roof and the hood if you can get the paint to match, then clay bar/polish/wax the panels that aren't peeling. It'd end up looking maybe 90% as good as a legit paint job, with much lower cost and effort, and way better than the average 1st gen.
    Oreo Cat likes this.
  12. Jul 28, 2017 at 9:51 AM
    Taco-bender
    Taco-bender Well-Known Member
    Tucson AZ
    2010 Tundra 4x4
    I'm pretty sure 1st Gen white doesn't have a clear coat. I know my son's '98 doesn't and an occasional buff gets it nice and shinny again.
  13. Jul 28, 2017 at 11:56 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    ^^^ This
    Though when I let it go and wash it, the wash water turns white. A little polish, a little wax and she shines again....
  14. Jul 28, 2017 at 3:53 PM
    surfwax
    surfwax [OP] Member
    Why would I need more than two spay guns? Or are you talking about prep work tools?
  15. Jul 28, 2017 at 4:01 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yes.
  16. Jul 28, 2017 at 4:03 PM
    Toyota4x46921
    Toyota4x46921 Well-Known Member
    Michael
    Warner Robins, GA
    I was rear ended...they had to put a new rear panel/fender on. Just that fender has clear coming off and is fading? What would be the cost on avg just for a rear fender painting on a 04 dbl cab...sorry for jacking the thread..
  17. Jul 28, 2017 at 4:04 PM
    kgt0001
    kgt0001 Well-Known Member
    Kyle
    San Antonio, TX
    2003 Toyota Tacoma PreRunner, 1997 Tacoma 4wd
    Need to ensure you have a a drier on your air lines- any moisture in spray lines and you will be sanding again.
    I would use a single stage color matched- much more forgiving (and more cost effective).
  18. Jul 28, 2017 at 4:07 PM
    austinsdad99
    1999 prerunner 3.4
    I still have the window sticker in the glovebox of mine, it was originally a Florida truck then wound up in south AL, now in central AL, so alot of hot hot summers. That would take a toll on any paint job i guess.. I have noticed alot of the jade/mica (green) yota's with bad paint though.
  19. Jul 28, 2017 at 4:09 PM
    surfwax
    surfwax [OP] Member
    How do single stage paints hold up in the long run?
  20. Jul 28, 2017 at 4:11 PM
    surfwax
    surfwax [OP] Member
    Yep, mines green and the hood, roof, and bed panels are peeling
    austinsdad99[QUOTED] likes this.
