Painting Wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by goldentaco03, Dec 27, 2015.
  1. Dec 27, 2015 at 5:28 AM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    The paint is chipping off my steel wheels and they need to be repainted. How should I prep them and what paint should I use?
    Liam
  2. Dec 27, 2015 at 5:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    Prep is pretty much like any metal work. Cleaning, sanding, cleaning, drying.
    Paint, same. Using outdoor grade obviously. Some self etching primer, then color.
    Duplicolor, Plasti-coat, Rustoleum all are decent products.
  3. Dec 27, 2015 at 5:33 AM
    C-Ya MK
    C-Ya MK Mike
    Southern California
    2008 Tacoma TRD Access Cab
    Check out Duplicolor videos on YouTube
  4. Dec 27, 2015 at 2:05 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    do you have a compressor, die grinder, and a drill wire brush? or just a corded drill and a wire brush? you could rip off the old stuff using one of these. an aluminum brush won't damage the wheel, just strip it.
    then just hit it with some rim paint.
  5. Dec 28, 2015 at 9:36 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    as mentioned, just do normal paint prep
    as to paint choice, I recommend epoxy paint since it is a lot more durable and scratch resistant then regular paint as well. that's why its the main type used for garage floors where lasting durability under abuse is the main requirement
  6. Dec 28, 2015 at 9:49 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Used duplicolor wheel paint. 1 can primer, 1 can paint (i used black), and 1 can clear done all 4 of mine. Minimal chipping after 20k and quite a bit of abuse
  7. Aug 5, 2017 at 12:46 PM
    Buckaroo1993
    Buckaroo1993 Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    I know this is an old thread but can this be used on the fender flares, front bumper assembly and grille/grille surround?
  8. Aug 5, 2017 at 2:25 PM
    goldentaco03
    Liam
    NJ
    I ended up using "aircraft paint remover" stripped all the wheels down to bare metal, then used rustoleum self etching primer and duplicolor wheel paint.
    most of the front bumper and chrome is plastic, you could use some bumper paint, plastidip, or rattle can rustoleum in your choice of color. I don't think any stripping for sanding would be necessary on those parts.
  9. Aug 5, 2017 at 2:27 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Rusto automotive primer will work if you feel like priming - not the filler, just the plain automotive is fine. I think we already covered your paint choices in another thread. I always wipe down everything with alcohol before painting it - isopropyl is cheap to buy at a grocery store or pharmacy.
    Scotchbrite pads are great for this kind of stuff if it's got shmutz all over it - I didn't even use sandpaper the last couple times I painted wheels and you definitely don't want to use sandpaper on textured plastic panels that will show any little knick or flat spot unless you plan to retexture it.
  10. Aug 5, 2017 at 2:41 PM
    Currygoat
    Currygoat Well-Known Member
    Bay Area, California
    2002 Tacoma 2.4 5 Speed
    Rims, 4600 Bilsteins, K&N filter
    Clean, Sand, Primer, Paint. Powdercoating rims is fairly inexpensive as well and you will get much better finish and durability.
