Panel fuse blowing immediately with radio plugged in
Discussion in '1st Gen. Tacomas (1995-2004)' started by toyota4x4az, May 21, 2024.
  1. May 21, 2024 at 4:30 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Yeah, a teenager in a rush did that butchery; just about guaranteed the issue is in that mess. Truck deserves to be cleaned up properly RE that wiring cobjob. Good tips here already, I just wanted to say yikes.
  2. May 21, 2024 at 4:32 PM
    toyota4x4az
    toyota4x4az [OP] Member
    This is what I would like to do. But the wires are spliced and crimped so far in, I can’t even see them or get to them. It’s going to take me ripping the entire truck apart
    Only green/red wire I can find connects to a 2 pin connector along with a green and white wire. That connector is not connected to anything. I think it would go to the clock, but my truck is not equipped with a clock
  3. May 21, 2024 at 5:08 PM
    toyota4x4az
    Alright I just found that coming down from up in the upper loom of wires, there is a green wire with red stripe. This wire is connected to the wire that is connected to the ground connector on the radio. What is even going on? I am so lost
    Update: Found that the brown wire coming from the top loom, gets spliced to a red wire, goes down the loom, loops back up to the top loom, and connects to the white/green wire.
  4. May 21, 2024 at 6:10 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    95 - 2000
    Kolter45 likes this.
  5. May 21, 2024 at 6:11 PM
    toyota4x4az
    Well I figured it out. It was exactly what I first thought it was, as well as ULURU. The green/red (Illumination) wire was wired into the ground wire to the radio. Why? I have no idea. And the white/green wire was wired into the factory brown ground wire.
    The radio turns on, as well as the lights. But I guess my question now is, what do I do with the white/green and green/red wires? Do they need to go to anything or can I just leave them disconnected and call it good?
  6. May 21, 2024 at 6:29 PM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    The green wire with the red stripe is the panel wiring. It shouldn't be going to ground. Disconnect that wire. If it is (was) the original illumination circuit for your radio, that is why your panel lights are shorting out. Whoever did the install did what my ex GF's dad did. Disconnect the GR-R wire, put a wire nut on it, tape it up, and secure it. You don't need it unless your radio supports dimming from the panel. Most aftermarket radios do not.
  7. May 21, 2024 at 6:32 PM
    toyota4x4az
    Perfect. Already half way done.
  8. May 21, 2024 at 6:35 PM
    ULURU
    Missed your follow-up post. Glad your found it.
    As I wrote above, you don't need the GR-R wire, unless you want to connect some cool under-dash foot-well lights. (I used to use old Christmas lights for this in my '78 Buick, and ran them off GM's panel light circuit - the grey wire I originally wrote about).
    I don't think you'll need to worry about the W-GR wire. That goes to ground, too. I'd do the same. Wire nut it, tape it, secure it, or use it as the ground for your foot-well lights.
