Panic, lost tool in diff! ECGS
Discussion in '1st Gen. Tacomas (1995-2004)' started by johnboyTRD, Dec 25, 2013.
  1. Dec 25, 2013 at 5:25 PM
    johnboyTRD
    johnboyTRD [OP] Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    I'm in full on panic mode... The effing ECGs puller tool piece fell into the diff!! How the heck do I get it out? Btw I did put paper towels In the diff to prevent this so I'm not full retard, just partially. Any ideas?
  2. Dec 25, 2013 at 5:27 PM
    pouyeux55
    pouyeux55 Member
    canada (QC)
    if your not in a hurry you can always open the diff cover and take the tool out .
  3. Dec 25, 2013 at 5:27 PM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    fish around with a flexible magnet and hope for the best. otherwise you'll have to remove the front diff and split it apart. good luck!
  4. Dec 25, 2013 at 5:27 PM
    johnboyTRD
    South SF bay
    Btw I realize this is second gen but they are the same for this purpose, and I'm (hoping) since more people have installed this for 2nd gen (issue not common with -st gen) that there might be a tip...
  5. Dec 25, 2013 at 5:29 PM
    johnboyTRD
    South SF bay
    Fuh.... That was what I was afraid of. I need to get a flexi magnet tomorrow I guess. Didn't know there was such a thing! I guess any auto parts store would have this? Man I am so bummed. Thanks for the tip man. Any others? Keep em' coming . Otherwise my next post will be asking how to reattach my head after wifey finds out that the 2hr job turned into indefinite.
  6. Dec 25, 2013 at 8:14 PM
    johnboyTRD
    South SF bay
  7. Dec 25, 2013 at 8:28 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    The tool that fell in, what does it look like?
    Can if fit out the drain plug? You may be able to look into the drain plug to see where it is. A boroscope would help with this too
  8. Dec 25, 2013 at 8:34 PM
    johnboyTRD
    South SF bay
    It's about 1/2-3/4" by 1.25" . Not to thick, maybe 3/8"? Def not coming out the drain hole BUT I may be able to use the drain to orient or better see where the tool is. Good idea!
    I'm really not that mechanically inclined so if you think of something 'obvious' please don't be shy :) I surely won't judge.
  9. Dec 25, 2013 at 8:45 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Give ECGS a call. They might have an idea for you.
  10. Dec 25, 2013 at 8:48 PM
    johnboyTRD
    South SF bay
    Thx, I will. Sent an e-mail this evening. What chase said in his video on install really concerns me though - something to the effect of 'block this off so you have a CHANCE of recovering the tool if it falls'
  11. Dec 25, 2013 at 8:51 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    You'll probably have to pull diff.
  12. Dec 25, 2013 at 9:06 PM
    johnboyTRD
    South SF bay
    Well , I certainly hope not. If i do... Can you provide insight on this ? Looks like once it is dropped, might be as simple as cracking the bolts around the pumpkin and removing tool piece, and installing bushing.
    Anyone know torque specs on these bolts, just in case? If you have an easily sent fsm, pm me, I'll give you my email.
  13. Dec 25, 2013 at 9:12 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
  14. Dec 25, 2013 at 9:14 PM
    east
    east Well-Known Member
    S.E. N.C.
    Stock 4x4
    Ouch, I am sorry to hear about your issue. Are there any forum members that live close to you, Someone might be able to help you. I hope you get it straightened out soon.
  15. Dec 25, 2013 at 9:21 PM
    johnboyTRD
    South SF bay
    That will be my last resort, once I'm b@!!5 deep in removing the diff. We'll see how the magnet tool works... Honestly I'm less scared of the diff than my wife if the truck isn't movable by Saturday.
  16. Dec 25, 2013 at 9:40 PM
    jessandjamie
    jessandjamie Well-Known Member
    Arizona
    I'll be honest I don't know what the ECGs puller tool is. But just in case you aren't aware...If you have to seperate the diff you have to pull both the axle shafts first, or it ain't coming apart...
    Edit:
    I think I figured out that its a bearing pulling tool. If so, I retract my statement since you probably already know and have at least one out.
  17. Dec 25, 2013 at 9:54 PM
    johnboyTRD
    South SF bay
    I followed a great guide on pulling out the axles. Just read the tutorial posted above from ECGs - need tierod end puller. Other than that I 'think' I have the tools and nards to attempt dropping the diff.
    Edit: I was shocked at how easy it was to disconnect hub and remove cv, especially with electric impact.
  18. Dec 26, 2013 at 6:06 AM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
    keep us posted
  19. Dec 26, 2013 at 6:12 AM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    I would try to find one of those hand held borescope cameras to borrow. You could insert it in the drain and see what you are doing to try to pull it out of the top.
  20. Dec 26, 2013 at 7:50 AM
    johnboyTRD
    South SF bay
    Yeah, I wonder if autozone rents them. I'll ask tonight.
