Panic, lost tool in diff! ECGS
Discussion in '1st Gen. Tacomas (1995-2004)' started by johnboyTRD, Dec 25, 2013.
  1. Dec 28, 2013 at 7:03 PM
    #61
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    :popcorn:
  2. Dec 29, 2013 at 12:07 AM
    #62
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    good to see!!!
  3. Dec 29, 2013 at 12:52 AM
    #63
    rat107
    rat107 Well-Known Member
    Kauai, HI
    2024 TRD Off Road 4x4, Automatic DC/LB Bronze Oxide
    aFe Momentum GT Cold Air Intake System w/ Pro DRY S Filter
  4. Dec 29, 2013 at 8:38 AM
    #64
    johnboyTRD
    johnboyTRD [OP] Well-Known Member
    South SF bay
    2003 Tacoma Double Cab TRD
    Full ome lift, nitro charger sports all 4 corners (rear shocks relocated), Dakar pack w/ AAL, 882 coils, diff drop, toytec 1" shackles, trail gear low profile front bumper, Tuff Stuff winch, bamf sliders, RAT skids, BAMF Bed Rack, Tepui Kukenam RTT, RAT rear bumper,
    Thanks, I got it. Watched before too. The tool is simply too tight, and is partially at fault for this. When I tapped the tool to seat. It dropped down partially behind the hole and a little nudge knocked it in.
    Still I should have known better and more adequately blocked the hole.
  5. Dec 29, 2013 at 9:17 AM
    #65
    TrdSurgie
    TrdSurgie revised
    Oahu
    I don't think the tool is at fault.... with that said, I probably would have lost it in the diff too.
  6. Dec 29, 2013 at 9:46 AM
    #66
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I've done 4 of these installs, and 3 of the trucks I had no problem with the tool at all. The last one I did, I did have to chamfer a little material off of it to get it to slide right in.
    First time I did it, I almost did this, but fortunately had it magnetized so it would stick in place. Used something like this http://www.sears.com/century-drill-...10725523810?prdNo=21&blockNo=71&blockType=G71
  7. Dec 29, 2013 at 10:09 AM
    #67
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    Magnetizing is a great idea! I'm going to do this. How did you chamfer the piece? Hit with a grinder on the far side? Where the little notches are?
  8. Dec 29, 2013 at 10:44 AM
    #68
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I used a dremel to chamfer it, but anything from a grinder to a file will do the trick. I put the piece in to the diff and took note of what was holding it up from easily sliding in. I pretty much just chamfered the front side outer edges and it slid right in no problem.
  9. Dec 29, 2013 at 11:01 AM
    #69
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Thanks.
  10. Dec 29, 2013 at 11:08 AM
    #70
    johnboyTRD
    South SF bay
    This, Dremel with grinding bit. Had to take quite a bit off. Just go slow and steady.
  11. Dec 29, 2013 at 11:11 AM
    #71
    johnboyTRD
    South SF bay
    If the tool was manufactured to the right size, a small tap would have done the trick to seat. That is how it looks in the video of install.
    Edit:
    Even after grinding down I STILL had to beat it in pretty good.
  12. Dec 29, 2013 at 1:50 PM
    #72
    johnboyTRD
    South SF bay
    Everything works, no more vibes.
