Pants shitting moment (got zapped changing plugs, now it wont start)
Discussion in '1st Gen. Tacomas (1995-2004)' started by Alderleet, Sep 16, 2012.
  1. Sep 16, 2012 at 12:27 PM
    Alderleet
    Alderleet [OP] Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Well, i was changing my spark plugs today, and i was using my really fucking nice torque wrench, when i came down to far torqueing the middle plug on the left side of my 6 cylinder. Sure enough, it touched the positive terminal and i got zapped.
    I luckily was pushing it with two fingers so release was easy when i got zapped, but i left if for a second to figure out the situation. thats when i noticed the torque wrench was still touching the terminal and it started to look like a weld was happening on the torque wrench handle
    I hit it off of there and layed down for a minute.
    I came back out, finished up changing plugs, and now the electrical system doesnt work. Its dead when i put my key in.
    Where the hell should i begin trying to diagnose the electrical problem?
  2. Sep 16, 2012 at 12:34 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Get the battery checked...Short to ground could drain it.
  3. Sep 16, 2012 at 12:39 PM
    Bfoster133
    Bfoster133 If i asked my dad for money, He'd knock me out
    Blake
    Thousand oaks, California
    2011 PreRunner TRD offroad
    15% Tint, 5100's at 1.75, Rear Diff Breather, CB radio, Black rattle canned rims, 265/75/16 Goodyear MTR, Magnaflow Offroad pro cat back, hi-lift bed mounted, shovel bed mounted
    x2 on the battery hopefully its just dead
  4. Sep 16, 2012 at 12:41 PM
    Polymerhead
    Polymerhead Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    Whoa, so you hit the positive terminal on the battery with your torque wrench? Did you have the neg terminal disconnected?
    I found one instance of this online but no real answer. I'd start by checking the battery - do your lights work, or any electrical at all? If you maintained the contact for a few minutes you could have drained your battery. Might try jumping it - it'd be the cheapest place to start.
    Good luck - subbed for the results.
  5. Sep 16, 2012 at 12:42 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Yea I bet its totally dead, my cordless drill batteries in the case would get a loose screw stuck in them and heat the screw up so damn hot it would stick into the plastic forever lol Batteries still work fine to this day!! Yay pre-b&k dewaults!
  6. Sep 16, 2012 at 12:44 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    :facepalm: Lol... sorry couldn't help muhself :devil:
    bet you won't do that again :D
  7. Sep 16, 2012 at 12:49 PM
    1stacoma
    1stacoma Well-Known Member
    Austin
    2012 MGM SR5 DCSB 4.0
    5100's front and rear, front 2.5" rear 2" AAL, 18% tint front and rear, color matched grill. SCS wheels 275/70/17 BFG AT KO's. DTRL toggle switch.
    My bet is the battery is dead or damaged. Even if you caused a more sever problem you should still get something.
  8. Sep 16, 2012 at 1:00 PM
    PB65stang
    PB65stang Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Definitely start with a battery, but a buddy just did this on his Jeep and it ended up needing a whole new ECU. Hopefully that's not your case.
    Always disconnect the battery when doing stuff like this!
  9. Sep 16, 2012 at 5:54 PM
    Alderleet
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    Okay, mystery solved (now i feel like an idiot, times 2)
    The truck was dead, completely. No interior lights, chime, or ignition
    Checked engine bay fuses (good)
    Checked cabin fuses (good)
    Checked for melted cables (good)
    Checked battery terminals (not good)
    Turned out, when i smacked my torque wrench away from the battery, I managed to knock the positive battery terminal clamp *slightly* (i mean really fucking slightly) and it couldnt maintain a circuit. :facepalm:
    I drove over to Napa, and they checked the battery. Its just fine
    However, my Snap On torque wrench handle looks like dog shit. Its got a couple good contact points, and a ark point at the top where it discharged against a cable holder on the plennum
    :mad:
  10. Sep 16, 2012 at 9:06 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
  11. Sep 17, 2012 at 4:33 AM
    Polymerhead
    Missouri
    Yup - best possible outcome! Lucky guy.
  12. Sep 17, 2012 at 7:37 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Think I'd be sending in the torque wrench to get it checked and calibrated again before I trusted it on important torque settings. Who knows. Just to be on the safe side.
    Glad you found what it was and it was not more serious!
  13. Sep 17, 2012 at 7:43 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Disconnecting the battery would have made no difference unless he disconnected it and removed it from the truck... Most cables have a cover for the positive terminal so something like this can't happen. Personally, I wouldn't disconnect the battery just to swap spark plugs either. Just gotta watch where you put your tools.
  14. Sep 17, 2012 at 10:52 AM
    BamaToy1997
    Bill
    Navarre, FL
    Sorry to hit you up on this, but you are wrong. If you disconnect the ground cable and place it safely away from the ground terminal of the battery, no amount of touching the positive terminal with a wrench or any other object would allow it to short. When you disconnect the ground cable, you remove the battery's ground circuit. It is not necessary to remove the entire battery. That being said, remember to disconnect the GROUND side, not the positive side.
  15. Sep 17, 2012 at 4:11 PM
    Polymerhead
    Missouri
    Oh Snap(on) - now I wanna know who's right.
  16. Sep 17, 2012 at 4:15 PM
    Pugga
    Massachusetts
    So you're telling me that if you disconnect the battery's ground, then run a wire from the battery's positive terminal to the engine block, nothing will happen? Cause you're essentially connecting the battery to a ground... I'm 100% sure cause I've never done it, but I'm not convinced it's a safe thing to do.
    I'm with Polymerhead, I want answers dammit! :D
    (plus we need to keep him talking so we can oogle his sig)
  17. Sep 17, 2012 at 4:36 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    i think your wrong..... haha.
  18. Sep 17, 2012 at 4:53 PM
    Pugga
    Massachusetts
    OK, so when you do electrical work on a car, do you disconnect the positive or negative terminal? I unhook the positive and leave the negative. You're saying I can leave the positive and unhook the negative and it's the same thing?
    My first rule is to remove the power source, screw the ground... if there's no juice, grounding becomes irrelevant.
  19. Sep 17, 2012 at 4:59 PM
    2012 Tacoma
    2012 Tacoma Well-Known Member
    Todd
    Illinois/Arizona
    2012 SR5
    Undercover Classic, TRD Skidplate, Wet Okoles
    I guess to test you would disconnect the battery ground and put a meter between the pos term and an engine or body ground. Might need the battery ground reference to make the 12V potential
  20. Sep 17, 2012 at 5:17 PM
    Pugga
    Massachusetts
    Alright, who's gonna be the guinea pig? :D
    FWIW, I'm beginning to think BamaToy is correct... :eek: Otherwise, you could discharge a AA battery by putting it positive side down on a piece of metal but instead it doesn't discharge unless the negative is grounded or it makes a loop.
