Papa Taco's Hard Caaaaarl Build and BS
Discussion in '2nd Gen. Builds (2005-2015)' started by Papa Taco, Feb 19, 2014.
  1. Nov 6, 2014 at 4:28 PM
    #641
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  2. Nov 6, 2014 at 4:29 PM
    #642
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Nov 6, 2014 at 4:31 PM
    #643
    Papa Taco
    Papa Taco [OP] HARD CAAAAAAARRRRRRRL
    Jared
    Socal
    2011 Access Cab 4x4 6 Speed
    Follow the yellow brick road
  4. Nov 6, 2014 at 4:33 PM
    #644
    T4RFTMFW
  5. Nov 6, 2014 at 4:35 PM
    #645
    T4RFTMFW
  6. Nov 6, 2014 at 4:36 PM
    #646
    Papa Taco
    Jared
    Socal
  7. Nov 6, 2014 at 4:41 PM
    #647
    T4RFTMFW
  8. Nov 7, 2014 at 1:28 PM
    #648
    T4RFTMFW
  9. Nov 7, 2014 at 1:29 PM
    #649
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  10. Nov 7, 2014 at 1:54 PM
    #650
    T4RFTMFW
    Workin' on picking up some nut/stems and tubing with correct Oetiker clamps for 10 feet of 3/8" high pressure tubing. LMK if interested.
    All you'd need is a wrench to attach the nut/stem to your cylinder and a tire filler with 3/8" barbed fitting. System complete.
  11. Nov 7, 2014 at 2:45 PM
    #651
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  12. Nov 7, 2014 at 2:50 PM
    #652
    T4RFTMFW
    Either of you.
  13. Nov 7, 2014 at 2:54 PM
    #653
    T4RFTMFW
    Could even add the filler with correct sized fitting and send all as one unit, ready to rock after attached to a cylinder. :notsure:
  14. Nov 7, 2014 at 3:36 PM
    #654
    T4RFTMFW
    I just set this up if you guys are game, I can get tubing, Oetiker clamps, nut/stem, used regulators, new regulators, compression washers, tire filler like the one shown (it's a Harbor Freight item). I can assemble a complete kit that is ready to go out of the box or I can send individual pieces, totally up to you.
    I can grab parts over the weekend or next week, depending on whether or not you want regulators. Used regulator might be $20, maybe less. Not looking to make money on this, but if it helps you out let me know, you pay what I pay (I have a connection on all of this equipment and can get it for much less this way) and I can probably throw it in a flat rate USPS box, or I can ship UPS if you prefer to pay extra for more assured shipping.
  15. Nov 7, 2014 at 3:45 PM
    #655
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Let me check my hoses and what have you and see what I have vs what would need to be built. I have two dual gauge regulators, but I believe they only go up to 80psi (homebrewproblems)
    Speaking of, it's time for a beer. It's been one hell of a day.
  16. Nov 7, 2014 at 3:49 PM
    #656
    T4RFTMFW
    80 PSI is plenty for tire filling, I'd think. I'm not sure what our cylinder is set at, but I'd be surprised it was over 50 PSI. Though I haven't fiddled with the pressure adjustment since I put the thing together in 2007, just locked down the nut and left it be.
    I can ship regulators setup for normal air lines, also, but the high pressure tubing is a cheap option that works beautifully and takes abuse. I can get any length of tubing, too, I just thought 10 feet would be enough to hit all 4 tires if you had the cylinder mounted in the bed. Could be wrong, but it comes in 1000' spools so I can accommodate, priced by the foot.
    If you were local I'd give you good deals on cylinders also but shipping would spoil any savings, probably.
  17. Nov 7, 2014 at 4:04 PM
    #657
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
  18. Nov 7, 2014 at 4:08 PM
    #658
    T4RFTMFW
    Nut and stem works, too.. but you have to be really aware of how much your valve is open so you don't blow your tire out and is a little sketchy.. Regulator is idiot proof and recommended, I can get used regulators with cylinder fill gauge and PSI gauge, possibly with just the PSI gauge depending on what is available.
  19. Dec 4, 2014 at 9:42 PM
    #659
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
  20. Dec 5, 2014 at 4:33 AM
    #660
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    OP has sold his truck and bought a Prius.
    :stirthepot:
