paranoia after doing first DIY oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NWtacoma, Mar 16, 2010.
  1. Mar 16, 2010 at 9:31 PM
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Could be some oil got splashed when removing the filter...what method did you use to catch that oil?
  2. Mar 16, 2010 at 11:20 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Just to be clear on this, I don't run straight water either (here in SoCal, I'd probably run 60/40 with water wetter since I tend to head into the desert in the summertime). I'm just saying that if you need to top off when you're a little low (less than 1/2 qt, which in this case it sounds like it might be) on an engine that's been filled with 50/50 mix, there's no real danger in adding just water, especially when you're topping off into an external reservior instead of right into the radiator. The added water will mix in quickly and you'll probably end up around 53/47 or so, especially if you top off just before driving somewhere.
    Probably not a good idea to top off with just water too many times in a row, and if it'll be getting down to single digits in the near future I'd definitely use premix instead, but Kent's a semi-mild climate, especially compared to Kalispell (I went to HS in Missoula and lived in Seattle for a coupe years since then)
  3. Mar 16, 2010 at 11:30 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    How much does the Pink Antifreze from Toyota cost?
  4. Mar 16, 2010 at 11:32 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    i drained my tranny fluid once thinking it was my oil :anonymous:
  5. Mar 16, 2010 at 11:37 PM
    NWtacoma
    NWtacoma [OP] Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    HOW!? lol:confused:
  6. Mar 16, 2010 at 11:37 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    20bucks.
  7. Mar 16, 2010 at 11:39 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    bah cuz theyre right next to eachother and it was my first time doing an oil change on the truck. so i was just rushing it... but you would think no big deal just fill it up right? wrong. its a sealed system so you only change the tranny fluid ever 100,000 miles and the dealer can only do it. it cost me 200 freaking dollars to get its filled with fluid. rediculous. a mistake i will never make again
  8. Mar 16, 2010 at 11:40 PM
    NWtacoma
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    they arent right next to each other. :rolleyes:
  9. Mar 16, 2010 at 11:42 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    um actually they are. Tranny fluid -> [___] [_] <- Oil pan thats an underneath view of my truck
  10. Mar 17, 2010 at 8:44 AM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    Actually, you can easily do it yourself and save $170. Next time you change it go buy 4 qts (~$30) and check out the DIY:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/63851-how-drain-refill-automatic-transmission.html
    I just did it this past weekend, it's pretty easy. :cool:
  11. Mar 17, 2010 at 8:51 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Not sure if that will make you feel any better but despite of doing quite of few oil changes I am still paranoid for few days after each oil change. How paranoid I am...?
    I carry wrench for oil pan and filter, plus 6 qt of oil with me plus I wipe the bottom of the engine with white cotton cloth.
    :D I can not help it its stronger then me I always think I screwed up somewhere. Even so I drive for 5K miles afterward.
  12. Mar 17, 2010 at 9:32 AM
    OffroadToy
    I believe the tranny fluid change interval is every 60,000. At least that's what my 07 owners manual says when doing any towing.
  13. Mar 17, 2010 at 9:35 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    thanks lol i dont think ill be making that mistake again lol
    nope 100,000 i looked it up and thats what the dealer told me
  14. Mar 17, 2010 at 9:45 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    Don't sweat it Panda, I dropped the tranny fluid in my wife's '06 Jeep GC the first time I changed her oil. As soon as I saw RED fluid coming out, I knew what I did. Couldn't close it up in time and had to completely refill it. That stuffs not cheap either!
    Though it was as simple as just pouring it in - unlike these new trucks.
    And like the others have said, you probably dripped or splashed oil during the change. Nothing to worry about. It's also why I bought a Fumoto Drain Valve - which replaces the drain plug with a valve that can be opened. Attach a hose to it run it right into the storage container (empty laundry detergent tub).
  15. Mar 17, 2010 at 9:46 AM
    #35
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    thanks eric :) yeah right when i pulled the plug and i got a little on my hand i thought to myself "thats not right." :laugh:
  16. Mar 17, 2010 at 9:48 AM
    #36
    nuckinfuts
    Pacific NW
    '06 AC TRD Off-Road
    ^They changed the recommended mileage for the drain/refill to 60k in November 2009. I changed mine at 76,500, but my manual says 100k.
    For a full flush, I've received different mileage intervals from 3 dealers I've asked ranging from 100k - 120k. Lots of bad info out there.
  17. Mar 17, 2010 at 9:49 AM
    #37
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    yeah i guess its different for wherever you go
  18. Mar 17, 2010 at 10:09 AM
    #38
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I would read the label on the back of the gallon container..........I bought mine from Toyota and it was not mixed 50/50........it specifically said to add water...........maybe they have changed since I replaced mine but make sure to read the label................
  19. Mar 17, 2010 at 10:19 AM
    #39
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    lol, my first oil change was for my dads GMC Safari. apparently I over tightened the oil plug and it pretty much kept rotating when we tried to get it off, had to go to a shop and have them drill it out or something. I used to get paranoid about if I did it right or not. after a while I just learned not to over tighten things, it's best if you don't really, not so that it's loose though. I always first tighten the oil plug and filter by hand, then for the plug I barely tighten it with the socket wrench. for the filter I hand tighten it only, you don't need much for it. After all that, I'm always in a dry area for a reason, which is to check for leaks after I start the vehicle up, esp. where the drain plug is. If you didn't tighten it right, you will see little drips and will be able to see some oil around the plug (sorry didn't mention this, but I always clean the plug after I take it out as well as around the drain area).
    So ... just park in a dry area, and see if your still getting that. If so, you can find where it's leaking fast, there will be oil kind of trying to cling onto either the plug or area where the filter is/close by. If you have a V6 4.0L 2nd gen, remember to clean out that oil trap real good. I just did my little cousins 06 and forgot to do that lol.
  20. Mar 17, 2010 at 3:55 PM
    #40
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    I do not see your vehicle information listed under your name. The older Tacomas used LLC that is red in color and is sold in gallons that are concentrated and require mixing. The OP has a newer truck that specifies SLLC that is pink in color and is only sold premixed. If you walk in and just ask for Long Life Coolant, the parts person may hand you the older fluid, no questions asked. The new fluid has a pretty specific chemistry and should not be mixed with hard or clorinated water. If you do find yourself needing to top off and add a little water (like mentioned in another post) you should add distilled water to the SLLC only. That is also good advice for any car and any type of coolant.
