Parasitic Draw Unknown Source
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackcat6, Feb 25, 2025.
  1. Feb 25, 2025 at 5:42 PM
    blackcat6
    blackcat6 [OP] Member
    2021 Tacoma Off-Road
    My 2021 Toyota Tacoma is getting Parasitic draw, and I have been unable to find where from -- Took to a mechanic, they could not find either.
    Info on truck:
    2021 TRD Off Road
    Only non OEM is Raptor lights, was the first thing I checked -- Not causing the issue
    Brand New Alternator & Battery
    Roughly 350 mA draw
    What I have checked with multimeter(s)
    1. Alternator (Incase faulty diode causing drain)
    2. Pulled Every Fuse & Relay While Monitoring via multimeter (allowed truck to go back to "sleep" after each fuse)
    3. Checked voltage drop across all fuses
    *Keys were far away from truck, and hood/door latches were flipped with screw driver as well as door sensor
    *From what I understand, mechanic tested everything I did and was unable to find the source of the draw as well
    *I've done my best to review all other threads on this topic
  2. Feb 25, 2025 at 5:49 PM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    If you pulled ALL the fuses in both boxes that should have been resolved.
    blackcat6[OP] and Dalandser like this.
  3. Feb 25, 2025 at 5:53 PM
    blackcat6
    I pulled them one at a time. If I disconnect main cable coming from fuse box to battery then yes the draw goes away. However, pulling each fuse one at a time does not drop reading on multimeter. Mechanic had the same result. I am certainly not an expert so open to any advice.
  4. Feb 25, 2025 at 5:57 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    The truck is not under warranty? What add-ons do you have? What electrical work have you done, if any? Check your OBD wiring if it has one of them dealer tracker thingys.
    BlackTRD4Me and blackcat6[OP] like this.
  5. Feb 25, 2025 at 6:13 PM
    blackcat6
    I bought it used. No add-ons that have anything to do with electrical (Ex: Bed mat, exhaust tip). Only electrical work would be that I installed raptor lights, but I checked that already. Previous owner could have had something done, but I did not see any signs of that -- They had a pretty detailed carfax. I didn't know about the dealer tracker thing, is it just inline with the OBD wiring -- I'll look for that.
  6. Feb 25, 2025 at 6:23 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I’ve done the remove each fuse method and had good results in the past, but came across this when helping a co-worker and say it could be worth it.
    https://m.youtube.com/watch?v=lRcj1fQcWwU&t=579s&pp=ygUTUGFyYXNpdGljIGRyYXcgdGVzdA==
    Less time consuming if you’re going over the test multiple times.
    How did you get the current draw - multimeter in series with the battery? Does it drop once you have it in series for a matter of seconds or minutes? How did you find out about the current draw? Is the battery draining over night once it’s fully charged? How long had it been sitting when it didn’t start for the first time? It’s good to test against having a failing battery as the symptoms can be similar to parasitic draw and coupled with a bad parasitic draw diag it can be difficult to get rid of tunnel vision.
    retracTRD and blackcat6[OP] like this.
  7. Feb 25, 2025 at 6:30 PM
    blackcat6
    I actually watched that exact video and followed all his steps. But was still unable to locate the parasitic draw.
    The battery is only a couple weeks old, I did have it tested and it is good. The battery will last from a few days to a couple weeks, then dies — I jump it and charge battery. It gets driven everyday, most recent time I drove home from work around 5 and it was dead the next morning at 8am.
  8. Feb 25, 2025 at 6:40 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    On ford, its always been the radio....
    blackcat6[OP] likes this.
  9. Feb 25, 2025 at 6:40 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Really need a Toyota tech to confirm, but I believe 350mA is within acceptable tolerance
  10. Feb 25, 2025 at 7:15 PM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    350mA sounds high to me, but it been a while since I last had the problem.
    Ironically, as mentioned above, the radio in my last F350.
    Either way, 350mA wouldn't kick a new battery in the nuts overnight.
    Something sounds amiss..
    slater likes this.
  11. Feb 25, 2025 at 7:25 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Got it. 350 mA is definitely over spec, but as stated, not the same as over an amp that will nuke a battery overnight. Another test you could do is pulling half of the fuses (a large chunk of them anyway) overnight and noting the battery voltage before and after you leave it for awhile. Repeat until you note which group is causes the most or all the draw and halve the number again and again until the last group or last fuse hopefully is found.
    MagicToolbox likes this.
  12. Feb 25, 2025 at 7:35 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    350mA is way over, 50mA is maximum although most vehicles will be under 20 when fully asleep.
    So you voltage drop checked all the fuses and got no drop on any of them?
    soundman98 likes this.
  13. Feb 25, 2025 at 7:37 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    It may also matter when the measurements are taken. Immediately after shutting off the vehicle, they will be high; after several hours the draws of all the modules go down. Except for that vac test the fuel tank does.
    soundman98[QUOTED] likes this.
  14. Feb 25, 2025 at 7:42 PM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    Do you have a IID installed? That could be draining your battery. :bananadance:
  15. Feb 25, 2025 at 7:53 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    what is NON FACTORY on it?......go from there
    retracTRD and BillF1564 like this.
  16. Feb 25, 2025 at 7:57 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    OP said only Raptor Lights. If his tests are valid, it would seem to be something coming on when it shouldn’t during sleep mode or once the truck’s been sitting. Unless anyone comes up with a useable test, I’d pull groups of fuses overnight / over longish time periods and record the change in voltage each time.
  17. Feb 25, 2025 at 8:01 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Random ideas, but since it's used- look for GPS bank tracker, remote start module, alarm module.
  18. Feb 25, 2025 at 8:02 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    The best test is checking voltage drop across fuses, determine which fuse(s) have current going through them, then look at wiring diagrams to see what they feed and develop a game plan. It's quite tedious to do voltage drops on all the fuses but on a modern vehicle you really don't want to be pulling fuses looking for a draw because you tend to "wake" things up then you have to wait for it to go back to sleep which on some vehicles could be an hour.
    It sounds like the OP is on the right track with that but we need to know what fuses are active.
    OnHartung'sRoad likes this.
  19. Feb 25, 2025 at 8:02 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Good idea as well.
    Chew[QUOTED] likes this.
  20. Feb 25, 2025 at 8:16 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    That was the test in the video I linked that OP said he already completed with no results. I’d target major connector or circuit groups like infotainment / communication / ignition / srs etc. since any time in the meantime could be making progress through this. It’s free and the vehicle’s sitting overnight anyway. Just my 2 cents.
