Parasitic Draw Unknown Source
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blackcat6, Feb 25, 2025.
  1. Feb 26, 2025 at 11:08 AM
    #41
    blackcat6
    blackcat6 [OP] Member
    2021 Tacoma Off-Road
    Not one that will test wires that small, or I guess be sensitive enough to read mA. Can look into that though
  2. Feb 26, 2025 at 11:30 AM
    #42
    Alakablamo
    Alakablamo Member
    2023 TRD OR Manual
    In multiple vehicles that I have helped to troubleshoot over the years, it was always the radio. For some vehicles, the radio would randomly NOT shut off (or would possibly "wake up" for some reason) when the vehicle was turned off. Modern radios are connected to both continuous and accessory battery, and many can be turned on by both the front panel radio controls, or even by canbus signals from the BCM or ECM.
    If it is an intermittent failure (as it seems to be), try pulling the radio fuse for a few weeks and see if the issue still occurs.
  3. Feb 26, 2025 at 12:41 PM
    #43
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    dont know if matters on op truck but mine will shut off whatever ever is draining battery after 30 mins.....like if the dome is left on
  4. Feb 26, 2025 at 6:50 PM
    #44
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Not going to be the case here, as it's something staying on, not over-drawing.
  5. Feb 26, 2025 at 6:57 PM
    #45
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I've had some success using a thermal camera but it only works when the vehicle has been parked overnight so everything has cooled to ambient temp, anything drawing power will be slightly warmer and will show up on thermal but if it's covered up by something you won't see it. Worth a shot though if you have access to one.
    A standard DC amp clamp will pick up 300mA, under 100mA they typically don't work.
    Have you looked around under the dash for any aftermarket nonsense that may be tapped into something?
  6. Feb 26, 2025 at 7:00 PM
    #46
    Glamisman
    Glamisman Well-Known Member
  7. Feb 26, 2025 at 7:12 PM
    #47
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    That only tells you if you have a draw (which we know we do) and how much it is (which we also already know (350mA). Just an alternative easier way to check for a battery draw, doesn't really help pinpoint what's causing it.
    Battery parasitic draw can be one of the worst things to track down on a modern vehicle, there is so many possible causes plus you can have one thing keeping other stuff awake which really can make it fun.
    soundman98 likes this.
  8. Feb 26, 2025 at 7:32 PM
    #48
    victorneyra
    victorneyra Member
    test with the fuse removed. remove one fuse at a time but do not put it back in...just keep going until draw goes away. DO NOT PUT FUSE BACK IN AFTER CHECKING
  9. Feb 26, 2025 at 8:13 PM
    #49
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    and don't lose track of which fuse goes where
