Parasitic draw when locked - 2005 Tacoma X-Runner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Calcul0n, Dec 31, 2022.
  1. Dec 31, 2022 at 11:05 AM
    Calcul0n
    Calcul0n [OP] New Member
    Hello everyone,
    I have a 2005 Tacoma X-Runner with 220k miles. It has had trouble starting recently, and so I went to the auto parts store and they did some diagnostics said battery seemed fine, and alternator also seemed fine. Battery is also only 6 months old. So, started to check for parasitic draw.
    With the car off, doors unlocked, and hood open, it draws 0.25 amps for a couple of minutes, then it drops to 0.04 amps. When I lock the doors, that draw goes up to about 0.12 amps.
    1. Can someone confirm whether or not the 0.12 amp draw when doors are locked is too much?
    2. Does the hood being shut play any importance here?
    3. I've checked all of the small easy to pull fuses in the engine bay, and under the dash (driver's side). Any other fuse locations?
    4. Should I pull any relays? Should I pull the big fuses? Both are a pain to pull out.
  2. Dec 31, 2022 at 11:11 AM
    Bishop84
    Bishop84 Well-Known Member
    I wonder if an actuator is sticking.
    0.080 is max 0.040 is ideal. Hood has no sensor or switch.
    The door locks are powered by the body ecu via a 20amp "DR LCK" fuse by the drivers kick panel. Remove that fuse first, then likely remove the door trim and isolate which may be causing the issue.
    b_r_o and Dm93 like this.
  3. Dec 31, 2022 at 11:13 AM
    shmn
    shmn Well-Known Member
    Pacific NW
    2007 Tacoma 2.7L 5sp
    0.12a is a lot for parasitic draw (120ma).
    Do you have any security systems (factory or aftermarket)? Aftermarket stereo? Aftermarket anything electrical?
    Calcul0n[OP], 4xdog and Dm93 like this.
  4. Dec 31, 2022 at 11:27 AM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Welcome to the forum. Great username.
    Good luck chasing down the draw.
    Calcul0n[OP] likes this.
  5. Dec 31, 2022 at 12:34 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    +1 on checking for aftermarket alarm
    4xdog likes this.
  6. Jan 2, 2023 at 4:41 AM
    Calcul0n
    Hey everyone thanks for the replies. You were correct It was an aftermarket alarm.
    Removing the DR LCK fuse didn’t change the draw. Then, I unplugged the connector going to the door locks in the door panels. Still too much (I guess kinda makes sense since pulling the fuse did nothing). Then, I looked under the driver kick panel fuse block, and there was still lots of stuff spliced into the oem wiring that was hidden near the fuse block in drivers kick panel.
    Removed all of that stuff and reconnected some wires and now draws 0.04 amps locked and unlocked. Feels good.
    Thanks again for all the [dramatic… pause] help!
    Too Stroked and b_r_o like this.
