Parents helping pay for suspension
Discussion in '5 Lug' started by Canadian Taco 705, Apr 28, 2014.
  1. Apr 28, 2014 at 7:45 PM
    Canadian Taco 705
    Canadian Taco 705 [OP] Well-Known Member
    Windsor Ontario Canada
    2010 Black 2.7L 2WD Debadged
    Interior: Hardwire GPS Hardwire USB x2 Extra Cig Lighter Mag Light Mod x2 Exterior: Debadged TRD hood Bull Bar Halo Headlights 6000K Lumens HID 50% Windshield Tint 5% Window Tint
    So I hit 154k km the other day and I need to update my suspension in my 2010 5 lug. Here are my problems
    Awful ride that needs to get better.
    Cracked rear leaf spring (left)
    Shocks that need to get replaced...
    So basically I'm a student (getting my architecture degree) and I got the truck new since than it's been all over North America pretty much all highway miles but some off-road.
    I use it daily want a good ride nothing that's going to hurt my back anymore than it already does.
    And I'd like to get a little higher in the air:
    It needs new shocks all the way around new coil springs as well as new leaf springs and shocks on all four corners
    Need you're help and will post pics when it's done
    Thanks
  2. Apr 28, 2014 at 8:10 PM
    Canadian Taco 705
    Budget is an issue I'm hoping to do it for less than a k
  3. Apr 28, 2014 at 8:18 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I would suggest Bilstein 5100's on all 4 corners and Eibach springs for the coils up front. That can all be bought for probably around $400-$500, you can probably pick up another set of leafs for about $100-400 depends on what you're looking for....and install will probably be under your budget
  4. Apr 28, 2014 at 9:22 PM
    Canadian Taco 705
    On a 5 lug u can't do 5100
  5. Apr 28, 2014 at 10:26 PM
    TCprerunner
    TCprerunner Well-Known Member
    There are a few posts on 5 lug lifts search aroundshould be plenty of info on a 2k budget you should have no problems
  6. May 29, 2014 at 9:56 PM
    Card1
    Card1 Well-Known Member
    Georgia!
    96 taquito
    Doestch Spindles
    Bilstein 4600. They're amazing
  7. Jun 4, 2014 at 5:41 PM
    Half Caf
    Half Caf Well-Known Member
    Philadelphia, PA
    2009: 5 Lugs, 5 speeds
    Second for the 4600s. They're on sale right now at 4wheelparts, too. I just picked up a set for the front for $72 ea. (vs $100 a piece at auto zone)
    Keep in mind that if you do get a lift you will need longer than stock shocks in the rear.
  8. Jun 5, 2014 at 6:33 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
