Park break not holding truck?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redtacomaginger, May 28, 2025.
  1. May 28, 2025 at 8:53 AM
    Redtacomaginger
    Redtacomaginger [OP] Member
    Taco
    3rd trd off-road Tacoma
    2018 3rd gen Tacoma here , I’ve been experiencing an issue and wanted to know if its common and what could be the reason for it , I got my truck 4 months ago , I’m a 3rd owner , the issue is that when I want to park my truck on a hill I push down the brake and then put it into N after that I pull up the hand brake and let my foot off the brake and I put it into P , however the issue is that when I lift my foot off the brake the truck rolls back , not an inch or two it fully rolls back and nothing stops it , so I find myself having to put the trucks weight on the P gear which ik can cause the gear harm in the future , would like to know the solution
  2. May 28, 2025 at 8:58 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Have you checked the pads and if they are actually compressing? Besides that you have a great habit of park.
  3. May 28, 2025 at 8:58 AM
    Redtacomaginger
    Taco
    Great habit of park?
    Phlogiston likes this.
  4. May 28, 2025 at 9:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    The rear brake shoes need to be adjusted. It's not a difficult process if all the hardware is in good shape. Several 'how to' posts around on the topic.
    Ptteddy likes this.
  5. May 28, 2025 at 1:03 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Easy to do if you know what you’re doing. Jack up the rear end, parking break off, chock the front tires, take off the tires and remove the rubber cover and start clicking away. Periodically check the parking break for tension.
  6. May 28, 2025 at 1:04 PM
    eurowner
    eurowner Duke Sky
    Scoty
    The parking brake adjusts the rear brake shoes. Use it more!
  7. May 28, 2025 at 1:11 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    Try slowly rolling backwards and using the parking brake alone to stop the truck. From what I have read on here, the rear drums adjust better when applied in reverse.
  8. May 28, 2025 at 1:23 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Based on the truck age, I would remove drums and clean insides and then proceed with adjusting shoes
  9. May 28, 2025 at 1:24 PM
    Vlady
    Issy, WA
    It does not work
  10. May 28, 2025 at 2:09 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Remove the rear drums, clean and adjust the shoes, put the drums and wheels back on and adjust a bit more through the slot in the back. Listen for a slight drag
    You can also pull up the cup holder tray and adjust the cable where it comes up through the floor
    The adjuster mechanism in the drum is supposed to self adjust but they never really do on their own.
    Ptteddy and wilcam47 like this.
  11. May 28, 2025 at 3:57 PM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    What others said. Since you third owner, how many miles on your 2018 Tacoma? Maybe time to do brake jobs, don't know if previous owners took care of Tacoma.
  12. May 28, 2025 at 6:37 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    12:25 into this video shows how to adjust the rear drums.
    https://www.youtube.com/watch?v=-dmUF5hbQEQ
    Ptteddy and eurowner like this.
