Park Neutral Switch help! Engine code p1780
Discussion in 'Technical Chat' started by CayucosTacoma, Apr 29, 2013.
  1. Apr 29, 2013 at 9:54 AM
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/Santa Barbara CA
    1998 Tacoma, 4x4 5 Speed, V6
    Specs in the Build Thread
    Ok so I have engine code p1780 which in the park Neutral switch..
    Got it replaced with a new sensor, and the engine code went away.
    But after starting the truck 3-4 times it came back on.
    Needs to get smogged soon and won't pass with this engine code!
    Any help is appreciated
  2. Apr 29, 2013 at 10:06 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    Not trying to be a smarty pants but.... you need to find out the reason the sensors are going bad, have you checked the grounds and wiring of that system?
  3. Apr 29, 2013 at 10:14 AM
    CayucosTacoma
    No offense taken dude. Any help is really appreciated. Checked grounds and looked good, wiring looked good I think. Ill double check but looked good to me.
    Think parts cleaner on the clip that goes to the sensor would fix my issue?
  4. Apr 29, 2013 at 11:24 AM
    PLC721
    Patrick
    Chandler, Az
    I dont know if it will fix the issue but it wont hurt anything! i personnaly took MAF sensor cleaner to most of the sensors on my truck over the weekend :thumbsup:
    How does the actual clip look?
  5. Apr 29, 2013 at 11:28 AM
    CayucosTacoma
    MAF Cleaner? Hmm i was going to pick up some Electric parts cleaner but its probably all the same.
    Uhm clip looks alright, definitely tight. It was near dark when i was swapping parts, the inside of the clip might be pretty dusty
