Parked Rang Rover Moves
Discussion in 'General Automotive' started by dmac11, Oct 7, 2010.
  1. Oct 7, 2010 at 4:46 PM
    dmac11
    dmac11 [OP] Well-Known Member
    CT
    '06 2x4 AC
    Upgraded Head Unit w/Aux jack : De-Badged : Black Emblem : x-runner Rims : Seat Covers : Optima Battery : AC Inverter (aftermarket) : Full time 12v : Weather Tech Front Mats : Scanguage
    Its a 1993 Range Rover. It rolls when i put it in Park. I feel it in-gauge, but it will slowly roll, like a clutch slipping. Any Ideas on what could be the problem?
  2. Oct 7, 2010 at 4:47 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2002 Tacoma Xcab
    the problem is that its a Range Rover
  3. Oct 7, 2010 at 5:07 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    lol!! You're an @ss! :D j/k
    OP, You say the clutch is slipping so I'm assuming it's a stick shift, but you also say when you put it in park? Please confirm if it's manual or auto.
  4. Oct 7, 2010 at 8:56 PM
    dmac11
    CT
    '06 2x4 AC
    Its a automatic. The slipping clutch was just an analogy. Sorry for the confusion.
  5. Oct 7, 2010 at 11:31 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    OK, well it sounds like your torque converter is not working properly, and it's not grabbing like it should. Or something internally in the transmission case is not working right.
    The only thing I can recommend doing is an oil change, but that may do nothing, or may delay the problem for a short while. But you never know, could fix the problem.
    I think you're going to have to end up taking it in to a transmission shop and they'll take a look at it. Could get lucky, could be something simple and cheap, bad linkage or something, but usually not.
    Hope everything works out with it.....
  6. Oct 8, 2010 at 12:01 AM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Well, I guess you out did me on that. From what he wrote, it sounded like it slipped from when he put it into drive, but I guess I read it wrong.
    You also completely changed your first comment, was a little more harsh towards me about what I said it was, but that's alright. As long as we figure out what it is.
  7. Oct 8, 2010 at 12:05 AM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    lol
