Parking brake adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RCN500, Sep 24, 2014.
  1. Sep 24, 2014 at 2:45 PM
    RCN500
    RCN500 [OP] Member
    Denver.
    @007 Tacoma, 4dr,long bed,Sport.
    Cold air intake and cat back exhaust.
    I have a 07 auto 4x4 and can't find a post about where the adjuster for the foot brake pedal is. Is it below the center console, behind the dash, where?
    I didn't want to start just popping trim off in case I unnecessarily break a tab or something. I've adjusted the back brakes though i'm not completely happy with it yet but just did the front pads and rotors and my brakes still feel spongy and the foot pedal travels way too far down.
    I'm going to bleed the system and adjust the cable once I know where it's at.
  2. Sep 24, 2014 at 2:49 PM
    SLOBRA
    SLOBRA LET IT EAT®
    Albuquerque, NM
    2012 DCSB 4x4 TRD O/R
    I had my center console off recently and noticed it under there.
    1) Remove shift knob
    2) Pull up center console
    Jimmyh likes this.
  3. Sep 24, 2014 at 3:09 PM
    RCN500
    RCN500 [OP] Member
    Denver.
    OK thanks, I figured around there but wasn't sure, i'll give it a go.
  4. Sep 24, 2014 at 4:31 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Adjust your rear brakes first.
  5. Sep 24, 2014 at 5:18 PM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    In the 4 banger manual trans models it's easy job to adjust. Just remove the cup holder behind the shifter in the center console. There is an adjuster nut, and a lock nut, both are 12 mm. I finally did mine today, and what a difference a couple turns makes.
  6. Sep 24, 2014 at 7:05 PM
    gearcruncher
    Canadain bumper technician
  7. Sep 27, 2014 at 10:18 AM
    tonyt915
    tonyt915 Well-Known Member
    My Name Is Toby!!!
    Tomball, TX
    2010 TRD Off-Road
    Pelfreybilt front bumper, SOS skis plates and rear bumper, Icon extended travel coilovers, Icon 2.5 w/resi's rear shocks, Dakar lead springs, Warn 9.5ti winch, Oem roofr rack
    ^ Awesome been wondering about how to adjust mine cause when I use it, I have to hold the pedal up by hand for a while so the light stays off when I disengage it.
  8. Jan 6, 2018 at 8:43 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
  9. Jan 6, 2018 at 9:07 AM
    Pigpen
    Dan
    Northwest Montana
    Same on V6 man trans
  10. Jan 6, 2018 at 11:42 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    How did you adjust the rear shoes?
    Tighten until the wheel locks then back off the adjuster 15 clicks. That is a proper adjustment by the service manual.
    CMD-KY likes this.
