Parking Brake Cable Broke
Discussion in '1st Gen. Tacomas (1995-2004)' started by tmantstud, Apr 2, 2009.
  1. Apr 2, 2009 at 12:14 PM
    tmantstud
    tmantstud [OP] High Mileage Work
    Kansas City, Kansas
    98 Tacoma high mileage
    Bed liner, Polk db651s speakers, JVC head unit, Coverking custom saddle blanket seat cover
    I went to set my parking brake to day in my 98 tacoma 5spd and the lever cam all the way out with no tension. It seems as though im going to need to replace the cable. What is the easiest way to replace the cable. Im not mecahnic guru but im not clueless about wokring on my truck, any help is much appreciated.
    Thanks
    Tmantstud
  2. Apr 2, 2009 at 3:33 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Have you crawled underneath to look at 'where' it broke?
    Is it actually broken or could it have come disconnected somewhere?
    I'm not too familiar with where or how it connects to the pull handle, but I do know (on a 3.4L) it connects to the tensioner near the middle of the truck along the frame rail.
    I would check the tensioner and make sure everything is intact, in case it came disconnected somewhere.
    A lame picture of the tensioner (so to speak).
    Other than that, you gotta find out exactly where it broke from. There's multiple cable sections.
  3. Apr 2, 2009 at 5:20 PM
    tmantstud
    Kansas City, Kansas
    the two back cables that go to the rear drums are still taught and visible but the single split off that goes up to the handle has completely broken off or i think it is because i am unable to locate anymore.
  4. Apr 3, 2009 at 4:19 AM
    Janster
    Jandy
    Lancaster, PA
    Where did it break? Near the front of the vehicle/at the handle? Or at the tensioner/adjuster (or near it)? Can you snap any pictures?
  5. Apr 3, 2009 at 9:06 AM
    tmantstud
    Kansas City, Kansas
    After further investigation today i found that the cable broke at the handle.
  6. Apr 3, 2009 at 1:39 PM
    Janster
    Jandy
    Lancaster, PA
    The only thing I can tell ya...without seeing things directly....
    I'd call Napa (or other auto store) and ask if they have replacement cable for that. Obviously, you'll probably need the entire front piece.
    You can look in the factory service manuals and look for the actual part and maybe even give Napa some info of exactly what you're looking for.
    http://www.ncttora.com/fsm/index.html (scroll down to your vehicle)
    **I only mentioned Napa because I've had good luck with them having other cable related parts for other vehicles I've owned.
    Good Luck!
  7. Apr 3, 2009 at 4:30 PM
    tmantstud
    Kansas City, Kansas
    Thanks for all your help ill try Napa and if that doesn't work ill call up my favorite toyota mechanic.
  8. Jul 20, 2009 at 6:17 PM
    YOTA95
    YOTA95 New Member
    bone stock
    I picked up some cable from home depot for less that $2 for 5 feet. I plan on rigging something up. I feel really good about this replacement.
