parking brake cable trouble.
Discussion in '4 Cylinder' started by Colin Lucas, Aug 14, 2013.
  1. Aug 14, 2013 at 7:45 PM
    Colin Lucas
    Colin Lucas [OP] New Member
    Colin
    Central P.A.
    97 Tacoma
    4inch suspensionlift, 4 inch body lift.
    I have a 97 Tacoma 2.7 ext cab and I cant find any information on the parking break cable any where. mine broke off where the cable enters the handle and it is worn in a few other spots so I would like to replace it but cant find any information on what will fit and what wont.
  2. Aug 29, 2013 at 2:13 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    I owned an 03 that had that cable snap twice. I took it to the dealer to replace. The reason for the cable failure was rust.
  3. Jun 16, 2014 at 3:55 PM
    homesweettaco
    homesweettaco Well-Known Member
    Mark
    Nederland, CO
    2000 TRD Black
    Camper shell, yak rack, pop-n-lock, ultragauge, 2 inch suspension lift, K&N Intake, blacked out grill, BHM with clear lenses, debadged, favorite mod: center console from '01 with REAL CUPHOLDERS!
    Were you able to replace the cable? Where'd you get the replacement and how difficult was it?
  4. Jun 26, 2014 at 6:02 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    You will probably have to get it at the dealer. After it's replaced I'd suggest you pack emergency brake cable points with antisize when you change the oil and grease the zerks. Mine snapped at one of the points because of rust and lack of lube.
  5. Jul 1, 2014 at 12:51 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    I thought I remember seeing parking brake cables on rockauto.com for the first gens. Mines missing the front section from the handle down to the lever under the cab, just haven't got around to ordering it.
