parking brake handle will not turn to release issue
Discussion in '1st Gen. Tacomas (1995-2004)' started by keakar, Oct 21, 2014.
  1. Oct 21, 2014 at 6:18 PM
    keakar
    keakar [OP] Well-Known Member
    karl
    louisiana
    my friends 99 prerunner parking brake got stuck and wouldn't release
    we had to use a pliers to turn the shaft because the handle wouldn't turn the shaft to release it.
    once we turned the shaft it released normally so it the handle doesn't grip the shaft anymore but its still connected together, its turns like its loose on the shaft and wont turn the shaft to release it.
    is there a way to fix it or does he need a whole new shaft arm or a new handle for it?
    it looks like there is a little cup that is like a connection between the shaft and the handle and it seams to not be connected inside
  2. Oct 28, 2014 at 6:58 PM
    keakar
    karl
    louisiana
    hmmm, lots of people looking but no comments yet?
    I guess no one has ever had their e-brake handle break loose where its still attached but not connected to the shaft anymore
  3. Oct 29, 2014 at 5:51 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Sounds like it is torn up on the inside. Find a schematic and see what failed in the handle,,might be simple.
    A crudded up e-cable system can cause a stuck handle. Backing plate pieces need to be blown out and lubed inside of that boot. Slider guides clean and free, cable in good health and adjusted right, rollers lubed, ect. Eyeball the whole system before just replacing handle pieces,,,if needed.
  4. Oct 29, 2014 at 5:56 AM
    BamaToy1997
    Bill
    Navarre, FL
    I know on the dash-pull parking brake handle you have to pull the trigger, then pull back slightly to release. If the trigger did not work, then the mechanism in the trigger may be broken. You would have to replace the handle to fix this because they don't sell rebuild kits that I am aware of.
  5. Oct 29, 2014 at 12:49 PM
    keakar
    karl
    louisiana
    so the handle can be removed?
    the brake works great its just the handle wont engage to turn the teeth 90* to allow it to return to the off position so you have to grab it with a pliers and turn it that way.
    he doesn't really use the e-brake and this is the first time he used it since he bought the truck 6 years ago lol. we had to move the shifter to remove the radio dash cover and that's how we found out the brake wouldn't release as it should without help
  6. Oct 29, 2014 at 3:07 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    My Daughter borrowed my Truck once, and when I got in I could not release mine either, it just spun. Then I turned it right and re-screwed it back in and it has been working ever since. try it.
  7. Oct 29, 2014 at 3:46 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  8. Oct 29, 2014 at 5:09 PM
    keakar
    karl
    louisiana
    hmmm, we tried turning it but it only turns up or down and returns sideways but it never gave the impression it could turn a revolution to screw it on or off :confused:
    there is nothing wrong with the e-brake, it works perfectly but the handle doesn't grip the shaft to turn it so it can be released. turning it with a pliers it releases perfectly just as it should.
    the problem is in the handle connection to the e-brake shaft, something in there isn't grabbing to let you turn the shaft to release it.
  9. Oct 30, 2014 at 6:19 AM
    CR, WA
    stock
    Amazing.
    I guess if you have a auto you could,,in a death defying pinch,,yank it into Park at speed. Doesn't work out so well for the parking pawl on the trans,,but hey,,the e-brake is extra weight in this case?. lol.
    He is soo close to having it work right,,and saving his and other young lives. I hope sincerely you help him get it fixed right.
